Ford Kuga MK3 MY2021 As-Built Spreadsheet
rglonewolf
- Vehicle: Ford Focus ST MK4 2.3L Petrol Race Red
Re: Ford Kuga MK3 MY2021 As-Built Spreadsheet
Hi, I've just programed my Kuga today.
ST splash screen (it is an st line after all)
Auto locks on drive (I like how it just adds the option in sync, nice feature)
Climate on the sync display
Voice controlled Climate (only the main temperature)
I have a few questions:
1. How do I display the heated seats and wheel on the Sync display?
2. Can any other commands be added to the voice for climate?
2. Does changing the ambient light setting to multicolor do anything?
3. Is there any other setting you think I should change?
Jay x
Jay x
Thanks your value contribution, below are programed to my 2020 Ford Kuga MK3 (Without APIM Sync 3, with ACM Sync 2.5)
However, the Auto Stop/Start, is not working. Can someone give me a hint?
For iACC and ISA, is Sync 3(APIM module) mandatory? If possible to replace ACM to APIM module?
- 截圖 2021-07-24 12.35.11.png (75 KiB) Viewed 4553 times
Hi all,
Great job discovering all these. Many thanks!
A couple of questions related to programming my Kuga Phev 2021.
1) I cannot see the IPC module, even though I have the HS switch on my ELM interface. Can someone provide me with a link where I can find the correct ELM interface?
2) Is there a way to turn off the Lane Assist feature by default. I hate that I have to turn it off every time I switch on the engine.
Many thanks for your replies.
Salve, ho provato ad attivare gli abbaglianti automatici, ma nonostante abbia messo tutti i parametri come indicato nel foglio di calcolo, continuano a funzionare normalmente con spia blù nel quadro digitale.
Ho molte voci che si riferiscono ad AHB in modulo IPC
E nel modulo sccm ho la vice auto High beam
Can I ask the guys that have made changes to their 2021 KUGA - did you make the changes directly in the modules themselves? I've read about Central Configuration but when I connect FORScan to my car there are no modules with CC listed
Cheers
Andy
Cheers
Andy
I made the change in the module directly - I now have auto door locking at speed.
NightlyWolf
- Vehicle: Kuga St-Line X
Hi lskg.
I am Italian and owner of a kuga st-line x 1.5 Ecoblue.
I'm also working on modifying parameters with Forscan.
At the moment I have made the following changes:
Added climate control on Sync
Voice temperature control
Added steering wheel control icon re-routed to Sync
Added windshield heating control icon on Sync
Added Sync seat heating control icon
Change logo Sync
Rear Passenger Notice In the Sync Menu
Perimeter anti-theft enabled
Enabled cornering of the fog lights
Disabled seat belt sound
Doors close at 20 km / h.
For this latest change my "Original AS Built" is not 7D0-09-01 xx1x xxxx xx (as indicated in your Spreadsheet) but 7D0-09-01 xx5x xxxx xx.
So I tried to replace the 5 with the numbers from 0 to 9 until I found the one that enables me the function.
But I wonder if the procedure I used is risky.
Then I noticed that by activating the Settings Menu location on the cluster some functions, while remaining visible on the sync, are no longer manageable by the sync itself (for example, in my case, the traction control).
If you can check it out too.
Last thing I was wondering if you knew how the "Automatic Reopening" function in the locks menu works.
I thank you so much.
We hope to be able to find many other changes.
Greetings.
Change logo Sync
Greetings.
lskg
- Vehicle: Ford Kuga ST-Line 2.0 EcoBlue MHEV 150cv 2021
Hi NightlyWolf,
for the "Doors Autolock at 20Kmh" you did your best; if the value you found works fine and doesn't cause other modules/functions to malfunction then that's fine.
For the sync/cluster issue it's normal behaviour, because some function are not manageable at the same time through sync and through cluster; so it's your choice.
If I remember correctly the "Automatic Reopening" function is the opposite of "Doors Autolock at 20Kmh"; it's open the doors under 20Kmh; it's also described in owner manual; i don't use it.
If you find something new don't hesitate to report it; i can test and report in my spreadsheet if it works.
Regards.
Regards.
