as always many thanks to FORScan guys for their amazing work.
I want share experience with my car and here https://docs.google.com/spreadsheets/d/ ... sp=sharing you can find my personal spreadsheet (feel free to use at your own risk).
I emphasize that the changes work for the specific configuration of my car, reported in the spreadsheet.
Relevant, for me, is the activation of Auto High Beam, the useful setting of the front fog lights and the control of the outage of front turn signal (i've replaced the standard bulb with led buld not fully compatible with CAN bus).
The only problem is with "DRL include park lamps" parameter; when enabled, DRL, instead full power, is dimmed with the knob in OFF position or with the knob in AUTO position during daylight.
I haven't found a solution yet.
Work in progress; if someone wants to report other working parameters I can try them and report them in the sheet.
Regards.
News as of 11/04/2021
Added a couple more things in the spreadsheet:
1- Climate Voice Commands (only configured Climate on SYNC 3 in the beginning, but no voice control).
2- Basic Alarm system: here things ar very interesting; if the vehicle is in lock mode and any of the doors are opened "without authorization", vehicle horn immediately start to scream and turn signal start to flash.
If the open one is the driver door (Perimeter Alarm Chime=Enable Driver), you have a chime from IPC for some seconds first (you have the time to disable lock) and then vehicle horn start to scream and turn signal start to flash.
The more interesting thing is if you have TCU module (SYNC Connect, modem,ecc.) and FordPass app connected to the vehicle, you obtain a push notification in app when the alarm is triggered.
3- Corrected the line "Using Front Fog with turn signal" considering that already set in original As-Built and renamed friendly name "Anti-theft" in "Alarm system".
Regards.
News as of 18/04/2021
Added a mod in the spreadsheet:
Enabled in IPC all vehicle settings related to driver assistance pack, wipers, mirrors, doors, illumination, etc...
I already had all this settings in APIM, managed by SYNC 3 screen (Driver assistance menu and Vehicle menu), but now in IPC too!
Many thanks to @swkhza for contribution!
Regards.
News as of 21/04/2021
Added two new mod in the spreadsheet:
Enabled in IPC the settings for Perimeter Alarm (thanks to @swkhza for contribution!)
Enabled in IPC the settings for Auto High Beam
Both require "Settings Menu location"="Cluster" mod in IPC.
Regards.
News as of 27/04/2021
Added new mods in the spreadsheet:
Park lamps as DRL:
I have "DRL include park lamps=Enable"; this works, but dim my DRL with the knob in OFF position.
Added four mods to enable full bright DRL with the knob in ANY position; YES, with headlights ON too!
And this override the dimming problem with "DRL include park lamps=Enable"!
Maybe only valid in vehicle without adaptive headlights; vehicle with adaptive headlights seems to not have the dimming problem with "DRL include park lamps=Enable".
Regards.
News as of 04/04/2022
Added new mod in the spreadsheet:
Rear camera can always stay ON at any speed while driving forward:
I have installed the "On-Demand Rear View Camera" mod (thanks to A-TEAM) in Sync3 and than i have the button to activate rear camera while driving forward.
But by default my car stop the video stream at 15Km/h.
With this mod in IPMB module the 15Km/h limit is disabled and now my rear camera can always stay ON (with use of "On-Demand Rear View Camera" mod button) at any speed while driving forward!!!
Regards.
