SkyActiv Mazda ASBuilt Configurations
Mr.Volo
Vehicle: Mazda CX-5, 2.5AWD, 2019
Re: SkyActiv Mazda ASBuilt Configurations
Post by Mr.Volo »
Hi Everyone, do anyone possibly know where is an option to change the selector knob and to enable/disable digital speedometer from km/h to mph and back in the IC module configuration?
คิซานะ
Vehicle: Kisana aupping 6544
Post by คิซานะ »
SNapEl wrote: Thu Apr 06, 2017 1:12 am The good people at mazda3revolution.com have done some fine work in discovering these functions that have been tested with SkyActiv Mazda's 3, 6 and CX-5.
I thought I'd share it here.
Do visit them at http://mazda3revolution.com/forums/2014 ... built.html to give them a shout out.
SSU:
731-01-01 B0 B1 B2 B3 B4 B5(checksum) in HEX
B1 - it is (in BIN):
b7 - 0 or 1 = function is not known
b6 - 0 or 1 = function is not known
b5 - 0 or 1 = function is not known
b4 - 0 or 1 = 0 - I-Stop OFF, 1 - I-Stop ON (Tested on CX5)
b3 - 0 or 1 = function is not known
b2 - 0 or 1 = function is not known
b1 - 0 or 1 = function is not known
b0 - 0 or 1 = function is not known
B2 - configuration mode wireless control (step-by-step opening):
b7 - 0 or 1 = 0-W/O Advanced Keyless Entry; 1-W Advanced Keyless Entry
b4 - 0 or 1 = 1-W Unlock mode (2-step); 0-W/O Unlock mode (2-step)
b2 - 0 or 1 = 1-W Unlock mode (2-step); 0-W/O Unlock mode (2-step)
731-01-02 B0 B1 B2 B3 B4 B5(checksum) in HEX
B0 - it is (in BIN):
731-01-03 B0 B1 B2 B3 (checksum) in HEX
B0 - wireless mode lock/unlock is ONLY displayed on monitor (for example it is possible to configure only display the "unlock Mode"(step-by-step opening) or together with "Lock when leaving car":
b6 - 0 or 1 = 1- NO visibility Lock when leaving car; 0 - visibility Lock when leaving car
b4 - 0 or 1 = 1-Visibility Unlock mode
b2 - 0 or 1 = 1-Visibility Unlock mode
RBCM:
7B7-01-01 B0 B1 B2 B3 B4 B5(checksum) in HEX
b7 - 0 or 1 = 0 - no auto door lock or 1 - auto door lock (activates door lock function in RBCM)
b4 - 0 or 1 = function is not known
b3 - 0 or 1 = 0 - 1x blinker when doors close from remote control or 1 - no blinker when doors close from remote control
b1 - 0 or 1 = 0 - no blinker when doors open from remote control or 1 - 3x blinker when doors open from remote control (w/alarm system)
B4 - it is (in BIN):
b6 - 0 or 1 = 0 - OFF 1 - ON (ability to lock doors when Ignition ON) tested on CX5
b3 - 0 or 1 = 0 - OFF 1 - ON (ability to lock doors when doors open) tested on CX5
b1 - 0 or 1 = 0 - if engine work then not possible open boot or 1 - if engine work then possible to open boot (from button on boot)
7B7-01-02 B0 B1 B2 B3 B4 B5(checksum) in HEX
b7 - 0 or 1 = no data on use
b6 - 0 or 1 = 0 - OFF Find My Car or 1 - ON Find My Car (Press lock button twice on remote controller, You will hear a shortly horn) tested on CX5
b5 - 0 or 1 = 0 - It does not allow to open the trunk in the Drive mode (D) or 1 - It allows you to open the trunk in the Drive mode (D) tested on CX5
b4 - 0 or 1 = no data on use
b3 - 0 or 1 = no data on use
b2 - 0 or 1 = no data on use
b1 - 0 or 1 = no data on use
b0 - 0 or 1 = no data on use
b6 - 0 or 1 = no data on use
b5 - 0 or 1 = 0 - no auto door lock or 1 - auto door lock (only for visible this function on CMU)
b3 - 0 or 1 = 0 - auto door lock or 1 - no auto door lock (only for visible this function on CMU)
7B7-01-03 B0 B1 B2 B3 B4(checksum) in HEX
b5 - 0 or 1 = Lighting Coming Home Light - ON
b4 - 0 or 1 = Lighting Coming Home Light - OFF
IC:
720-01-01 B0 B1 B2 B3 B4 B5(checksum) in HEX
B2 - it is (in BIN):
b4 - 0 or 1 = 0 - disable I-Stop; 1 - enable I-Stop (enable/disable button I-Stop and view logo "I-Stop" on Instrument Cluster)
720-01-02 B0 B1 B2 B3 B4 B5(checksum) in HEX
b7 - 0 or 1 = 0 - Digital display Cruise control on IC; 1 - NO digital display Cruise control on IC
720-04-01 B0 B1 B2 B3 B4 B5(checksum) in HEX
B0:B1 - it is checksum for full configuration of car (IC)
720-04-14 B0 B1 B2 B3 B4 B5(checksum) in HEX
b5 - 0 or 1 = 1 - W ALS (Headlight Auto Leveling System); 0 - W/O ALS
b4 - 0 or 1 = 1 - and if b5 = 0, then AFS and ALS (Adaptive Front Lighting system) is OFF, if b5 = 1, then AFS and ALS is ON; 0 - and if b5 = 1 then only ALS is ON
720-04-23 B0 B1 B2 B3 B4 B5(checksum) in HEX
b6 - 0 or 1 = 1 - Cruise Control with LIM
b5 - 0 or 1 = 1 - Standard Cruise Control/MRCC
b4 - 0 or 1 = 1 - W/O Cruise Control/MRCC
720-04-27 B0 B1 B2 B3 B4 B5(checksum) in HEX
b3 - 0 or 1 = 0 - analogue rear view camera W/O path assist lines or 1 - rear view camera with path assist lines (rear view camera with CAN bus)
for example:
edit string in configuration
7B7-01-03 0018 5400 2E
on
7B7-01-03 0018 9000 6A
adds features:
- RAIN SENSING WIPER
- AUTO HEADLIGHT ON
String 7B7-02-01 no need to change. This string enables/disables activated features, it can be done in media settings.
Connect to study.
