Downloading Extended License Issue
Re: Downloading Extended License Issue
this worked for me so thanks. One thing I did notice was that in Windows 10 I'd not verified my identity in my user profile even though I thought I was administrator it wasn't working, once I'd done that it all worked perfectly.
Thank you Malster, After spending too much time trying to get the license loaded, your little tutorial from a while back did the trick.
I've registerd.
i've download the program and it won't open, shows as a adobe file.
help, i'd like to get my license key.
- Vehicle: *** Ford ***
Re, I 've download the program and it won't open, shows as a adobe file.
What did you download ??
This fix did the trick. Thanks!!!
Brent S
2018 F150 Lariat 3.0 PS
mikec243@gmail.com
- Vehicle: F-150, 3.5 ecoboost, 2015
[/quote]rmarrlow wrote: Tue Oct 09, 2018 3:12 pm This worked perfect for me. Thanks for the post!
I use WIN XP on my my Laptop. NO problems with Extended License...
But I see some people got problems with WIN 10 ...
I installed Forscan on my PC running WIN 10...and yes there is a Problem with actuating the extended license...
This is what I did...
Download the extended license...make a new folder and name it License. Put the extended license .key file in to that folder.
Go to Windows (C:) and find the FORScan Folder... Mine was in Program Files (x86)
Paste the " License Folder " in to FORscan...
Or: Right click on ForScan shortcut, Properties, Open File location...put License Folder in there.
Next:
Open the FORscan program
Click on [ Load License Key ] and this should take you here..
Open License Folder and take it from there...
When done it should look like this:
Hope it works for you as well !!
NO Problem at all ...
Thank You, Your step of copying the original file into a new folder, then opening it that way worked flawlessly.
No Problem at all
Absolutely worked great! Thank you so much. I was getting so frustrated.
