Note about old/new Extended License keys (starting from FORScan v2.3.22)
alexgrinsr56
- Vehicle: Ford F150, 2016 XLT, 5.0 L, RWD
extended license activation
After downloading the license to my download folder it would not instantiate after double clicking on it. recognizing it as a .reg file, I renamed it to a .reg file and loaded it that way. will this work?
genericfarms
- Vehicle: 15 f150 3.5
Re: Note about old/new Extended License keys (starting from FORScan v2.3.22)
Recently, I seem to only be able to generate a trial license, when I attempt to change a setting in PCM or BCM, forscan tells me a I need an extended license. I never had this issue in the past, and I am only looking to perform basic modifications, such as retrieve keyless entry code and disable horn chirp.
- Vehicle: *** Ford ***
Have you checked the Date on your Computer ... to make sure its up to date ?genericfarms wrote: Thu Jul 09, 2020 2:22 pm Recently, I seem to only be able to generate a trial license, when I attempt to change a setting in PCM or BCM, forscan tells me a I need an extended license. I never had this issue in the past, and I am only looking to perform basic modifications, such as retrieve keyless entry code and disable horn chirp.
Re: extended license activation
alexgrinsr56 wrote: Thu Jul 09, 2020 8:45 am After downloading the license to my download folder it would not instantiate after double clicking on it. recognizing it as a .reg file, I renamed it to a .reg file and loaded it that way. will this work?
Follow my instructions here :
Forscan License http://forscan.org/forum/viewtopic.php? ... f=5&t=5775
genericfarms
Yes, thanks, the computer date is correct, as is updates. I dont get any new information on the forscan app when I load the new license. I load the new key, program restarts and issues remain. any help is greatly appreciated.
key
key
FreedomPenguin
- Vehicle: 2017 mustang ecoboost premium
issues with extended license key. ive had no issues for 2 years, i had 2.4 beta forescan, i put new license key kept giving me errors etc. even though i jjjust created a new key.
i downloaded the 2.36 i think, made another key, its refusing to let me access anything. i am working on a mustang and when i click apim as built as, it says need extended, but i just created extended and loaded it like 20 times. and restarted laptop and program several times.
is there an issue going on at the moment? its acting like its not recognizing the extendfed keys generated
Thanks so much to FORScan Team, i just get a trial license key!
I received my extended license key but I can not get it to open and get the key number. What should I do?
Open it in Forscan as per this topic:viewtopic.php?p=63970#p63970, or this topic: http://forscan.org/forum/viewtopic.php? ... f=5&t=5775jbmush wrote: Thu Jul 22, 2021 8:27 pm I received my extended license key but I can not get it to open and get the key number. What should I do?
Either way works!
Hello, I can not recover the activation code how to do this
