Note about old/new Extended License keys (starting from FORScan v2.3.22)
Extended License was added in FORScan v2.3.0 and available since that time. Extended License protection system is 3rd party development licensed by us. Unfortunately, in some very rare cases (app. once per 500 installations) it didn't work for unknown reason: even although Extended License key is valid and installed properly, it doesn't unlock the Extended License. So we had to upgrade/replace the protection system in order to fix the problem. So now we have old Extended License keys (generated and used in FORScan v2.3.0..v2.3.21) and new Extended License keys (generated and used starting from FORScan v.2.3.22). It must be noted that Extended License functionality is identical for both new and old keys.
Unfortunately, it is not technically possible to provide full compatibility between old and new keys. Extended License keys are now forward compatible: old keys work only in FORScan versions prior to v2.3.21 (inclusively). New keys work in both new (v2.3.22+) and old (v2.3.21-) versions. So now we need all existing users to change their license keys. To provide a smooth process, we have dediced to make a transition period. During this period that is planned to be 3-6 months or so, we will release 2 versions of FORScan for Windows: version that supports old keys and version that supports new keys. If user installs the version with old keys, it doesn't need to do anything with the license key and everything will work as before. Version with new keys will require new keys to be generated and installed. Users who have free 2 months license will need to generate, download and install new license keys. Users who have paid license will just need to retry the activation with their activation code.
After transition period only version with new Extended License keys will be available.
Airborne_Ape
- Vehicle: F150 Hybrid 2021
Re: Note about old/new Extended License keys (starting from FORScan v2.3.22)
Are you saying there is no way for users who bought a lifetime licence (for old versions up to 2.3.21) to transition their old purchased key to a new key?
lenko
- Vehicle: 2015 Lincoln MKC(Sold), 2006 Mustang GT, Saleen 530 HP
Have lifetime license and downloaded for old keys, updated and it works.
How do users with an old key transition to a new key?
I have a lifelong licence. I installed the version with new license key and used the same activation key I received when I purchased the lifelong licence and it worked. Very simple.
TALLER KM38400
- Vehicle: ford ranger 3.0
buenos dias instale la nueva version 2.3.25 tengo licencia en extendida y beta funciono con las dos en sus respectivas notebokk si te da mas opciones la licencia extendida y funciona muy bien en la linea mercosur te deja hacer muchas funciones que con la licencia gratis no saludos a todos
I had a license extended a long time ago ... now I would need it because I have to program a focus of 2005 about that the instrument panel was not working.
how can I do?
how can I do?
- Vehicle: *** Ford ***
Easy ... Get a new one:extlic.php
Can I move my licence from old to new laptop? Or must buy new?
