Testing firmware update function for Ford modules
Re: Testing firmware update function for Ford modules
if you are using a FORScan old car profile that displays an APIM module, the old original software may have been successfully installed
I have done this once with IPC
viewtopic.php?f=13&t=13091
JensG
Vehicle: Focus MK3, TDCi 1.5, 2017
Post by JensG »
LaForge wrote: Mon Jun 15, 2020 8:00 am If its dead, then you are stuck.
It's not completely dead, "only" the screen is black and all sync3 buttons have no function. It shows up when scanning for modules on the HS CAN and I can also scan for DTCs (none logged) and run the module reset. On the other side the module self test gives an error: "Vehicle conditions are incorrect".
JensG wrote: Mon Jun 15, 2020 6:51 pm
what OBD adapter do you have :?:
JensG
Post by JensG »
fordsmax471 wrote: Mon Jun 15, 2020 7:22 pm what OBD adapter do you have :?:
I've the elm327 with ms/hs-can switch and the faster els27.
benk016
Vehicle: 2013 Ford Fusion Titanium 2.0L AWD
Post by benk016 »
I would like to get the beta version of the software if possible. I would Like to try the module update features.
Simy81As
Vehicle: ford focus 2.0 tdci 115cv
Post by Simy81As »
PM thank you
phnahes
Vehicle: Ford Focus MK3.5 - GDI_2.0L 2016 Flex Fuel
Post by phnahes »
I would like teesting this!
Because I need reprogram my Ford Focus mk3.5 PAM module, for flank guard works... :)
mandelbloom
Vehicle: ranger 2019
Post by mandelbloom »
Is it possible to get 2.4 now? I upgraded my 19 Ford Ranger to 3.4 and wanted to upgrade the APIM unless that is not recomeneded?
Thanks!!
hwk
Vehicle: focus mk4 1.5 ecoboost 2018
Post by hwk »
Can I also sign up for 2.4 beta, please?
cfhgarza
Vehicle: escape, 2.0, 2014
Post by cfhgarza »
Are you still accepting new testers? I need to calibrate my APIM for it to be able to display radio logos and I don't want to pay a dealership to do it.
