Auto lock enable 7D0-09-01 xx5x xxxx xx ->7D0-09-01 xxDx xxxx xxNightlyWolf wrote: Wed Sep 01, 2021 7:07 pm Hi lskg.
I am Italian and owner of a kuga st-line x 1.5 Ecoblue.
I'm also working on modifying parameters with Forscan.
At the moment I have made the following changes:
Added climate control on Sync
Voice temperature control
Added steering wheel control icon re-routed to Sync
Added windshield heating control icon on Sync
Added Sync seat heating control icon
Change logo Sync
Rear Passenger Notice In the Sync Menu
Perimeter anti-theft enabled
Enabled cornering of the fog lights
Disabled seat belt sound
Doors close at 20 km / h.
For this latest change my "Original AS Built" is not 7D0-09-01 xx1x xxxx xx (as indicated in your Spreadsheet) but 7D0-09-01 xx5x xxxx xx.
So I tried to replace the 5 with the numbers from 0 to 9 until I found the one that enables me the function.
But I wonder if the procedure I used is risky.
Then I noticed that by activating the Settings Menu location on the cluster some functions, while remaining visible on the sync, are no longer manageable by the sync itself (for example, in my case, the traction control).
If you can check it out too.
Last thing I was wondering if you knew how the "Automatic Reopening" function in the locks menu works.
I thank you so much.
We hope to be able to find many other changes.
Greetings.
Ford Kuga MK3 MY2021 As-Built Spreadsheet
Re: Ford Kuga MK3 MY2021 As-Built Spreadsheet
lincoln corsair 2020 2.0T Chinese edition
Email:swkhz@163.com
Email:swkhz@163.com
NightlyWolf
- Vehicle: Kuga St-Line X
Hello swkhza.
Thanks for your intervention.
I'd like to ask you something.
I did not understand how you managed to locate the letter "C" using the photo you posted.
Why is the letter C correct and not another value?
Thank you so much.
Greetings
Thank you so much.
Greetings
hex 1 = binary 0001
hex 5 = binary 0101
Auto Lock enable binary 0*** ->1***
Hex 5(binary 0101) - > Hex D((binary 1101))
Sorry, my calculation is wrong. It should be “D”
hex 5 = binary 0101
Email:swkhz@163.com
Email:swkhz@163.com
NightlyWolf
Hello swkhza.
OK! I got it.
A thousand thanks.
But do you have other AS build code images with other modifications?
Where did you find the image you posted?
Thanks.
Greetings.
OK! I got it.
A thousand thanks.
Thanks.
Greetings.
This is a spreadsheet I created for Lincoln Cosair Chinese EditionNightlyWolf wrote: Tue Sep 07, 2021 11:46 am Hello swkhza.
OK! I got it.
A thousand thanks.
Thanks.
Greetings.
Email:swkhz@163.com
Email:swkhz@163.com
david stockman
- Vehicle: ford kuga 2.0 tdci
Hi does anyone know how to activate the rear seat check minder in sync screen when you turn car off ? it’s not on my 2020 model but it’s on my friends 2021 model ?
Hi, I'm new to the forum and the Ford world.
I've been reading the forscan forum for days.
I have a Ford puma 155Hp Vignale for just 7 days and I would like to activate the automatic closing and the alarm.
Could you tell me if the parameters are the same?
Also, must the AssBuild parameters also be modified?
I am confused about this, because on some videos on the internet I have not seen the AssBuild modification.
Excuse my English, I'm Italian.
Thank you!
Thank you!
KrstGor
- Vehicle: Ford Kuga 1.5T EcoBoost AT 150HP (2019 MK2.5)
What a great work, thank you so much!!
I have one question, regarding the "Cornering with fog lamps".
Do you foglamps dim out slowly or they just come on and off instantly illuminating?
If so, is there a setting to turn off dimming effect?
lskg
- Vehicle: Ford Kuga ST-Line 2.0 EcoBlue MHEV 150cv 2021
Hi KrstGor,
for cornering the fog lamps dim out slowly and IME there isn't a setting to turn out the dimming.
If you find it, please let me know.
Regards.
Regards.
First of all, I would like to thank you for a great job.
I have also activated AutoHighBeams according to the published spreadsheet. In the IPC settings I have only enabled AutoHighBeam Telltale (see picture). I had to configure SCCM via AS-build, because using simple configuration will write `724-02-01 xxxx xCxx xx` instead of `724-02-01 xxxx x8xx xx` and create a DTC error from that.
I'll try it when it's dark.
