does anyone found the configuration byte for those models? I have the same on EcoSport (it´s only up to 726-27) :/semiho wrote: Thu Oct 03, 2019 9:55 pmBCM’s are quite different, so configuration byte of S&S is also different for Focus/Kuga/Escape/C-Max etc.Focus-MK4 wrote: Fri May 10, 2019 3:58 pm I wanted to try it on the new Focus 2019 but the BdyCM hasn´t the 726-48, it´s only up to 726-27
Anyone an idea?
Method to disable auto stop / start found
Re: Method to disable auto stop / start found
Any luck finding this anyone??? same on the Lincoln MKC... only goes up to 27.
Baltic
- Vehicle: Ford Transit Custom 2018. 2.0 EcoB 95kW
Hello all!!
Must register to here and buy Forscan.
Is this method still valid and what those XXX are in coding? Bit confused
Transit Custom
Transit Custom
lenko
- Vehicle: 2015 Lincoln MKC(Sold), 2006 Mustang GT, Saleen 530 HP
Still available and the X's are the positions of letters or numbers you don't touch when programming.Baltic wrote: Wed Feb 26, 2020 12:56 pm Hello all!!
Is this method still valid and what those XXX are in coding? Bit confused![]()
Transit Custom
Baltic
Ok now I get it, thanks!
Will try this when my cable arrives.
- fordsmax471
don't forget to backup the modules when the cable arrives
https://www.youtube.com/watch?v=4Opz1oa2_n0
Same here, with Focus Mk4 and Fiesta ST Mk8, BdyCM doesn't have the address mentioned, it goes only up to 726-27. BTW, I've successfully disabled the menu in the IPC, the address mentioned is present and working, menu in IPC has gone. Also tried to set the start/stop bit in APIM, but nothing changes, the start/stop is always enabled. Anyone have another BdyCM address to test? If yes, I can test it.
I tried it on a 2019 F-150 XLT and it appears to be working. Anyone know what this actually changed?
- Vehicle: *** Ford ***
Fresh_1 wrote: Wed Mar 04, 2020 2:37 pmI tried it on a 2019 F-150 XLT and it appears to be working. Anyone know what this actually changed?
Easy, Works on 2018 F-150 XL
FCIM Configuration Module
"Start/Stop Button Disable" Enable to Disable
IPC Configuration Module
"Auto Engine Shutdown with Memory" Enable to Disable
BdyCM As Built Module
726-48-02 x1xx to x0xx (first 4 digits)
