bogiediver
Vehicle: 2012 Ford Escape XLT V-6 4WD
Post by bogiediver »
twiggs462 wrote: Mon Nov 05, 2018 4:35 am
Golfman454ss88 wrote: Sun Apr 15, 2018 3:21 pm I wish there was a spreadsheet for escapes.
I’m looking for this as well... anyone have a list of as build data for escapes (namely 2014 in my case) thanks for any feedback.
+1
Specifically 2012 in my case...
Any help appreciated!
chuba9
Vehicle: Expedition, 3.5l EcoBoost 2018
Post by chuba9 »
im new to forums so please tolerate me!
ive been trying some of the 2018 expy changes and 1 thing i found is that some work with engine running and others in acc mode
working so far: bambi,remove splash screen,Lincoln black label background,nav in motion,removal auto start/stop,seat controls on touch!
johnb3
Vehicle: ford fusion 2015 titanium
Post by johnb3 »
Does anyone know the AS Built in data for a ford fusion 2015 titanium. My automatic climate control is on my sync 2 screen but when I press the button, nothing happens. I want to reset the APIM module but I do not have the codes to do so. PLEASE HELP
choppermike
Vehicle: 2013 Escape, 2013 F150
Post by choppermike »
bogiediver wrote: Mon Nov 05, 2018 6:27 pm
+1
2013 for me, would love one!
CTI-Kws
Post by CTI-Kws »
Is there any as built configuration & programming for the IPC messages on a 2019 super duty?
tdyer
Vehicle: F150, 3.5 Ecoboost, 2013 Platinum
Post by tdyer »
2013 Platinum is my truck. I am trying to make changes in my IPC as built. For some reason I can only see 3 rows of data. Most all spreadsheets have many more for all year trucks but I dont seem to have it? I have switch in my ODB with HS/MS. Both work and I seem to be getting everything for all other modules.
Any help or guidance appreciated.
I want to disable the seat belt minder on my 2013 and also want to stop the singing sound when door is open with keys in ignition.
Thanks in advance.
Trey
Eco_Boosted_2014
Vehicle: F-150 Xlt, 3.5 EcoBoost, 2014
Post by Eco_Boosted_2014 »
I’m looking for a build sheet for a 2014 F-150 EcoBoost 4x4 crew cab. If anyone has this info I would greatly appreciate the help
bud33doyle
Vehicle: ford f150 twin turbo 6 cyl 3.5l 2017
Post by bud33doyle »
I have submitted my vin# on the correct page to get module codes, but it will not download. Any suggestions?
LahainaOhana
Vehicle: Fusion, Gas 2.5L, 2017
Post by LahainaOhana »
This is kind of a no-brainer, but I had to learn it the hard way. If you replace a module on your car from a wrecker, you need to load the as-built programming into that module for your VIN. I bought a Texas flooded 2017 Fusion that had 586 miles on it. I've replaced many modules including the Shift Control Module, ACIM, ACM, BECMB, and others. When I installed them they seemed to work, but I'm realizing that some of the weird things that are going on is because of the wrong code. Forscan is priceless!
Thanks.
narrco
Vehicle: Ford Ranger Wildtrak (P375/J26E) 3.2 TDCI 2016
Post by narrco »
FORScan wrote: Fri Jun 23, 2017 11:28 am Here are some very helpful resources created by enthusiasts:
1. Tutorials:
Great FORScan tutorial created by Livnitup from F-150 forum. It was developed for F-150, but the principle of work with As Built data can be applied to any model.
2. As Built decodings
2015-2018 F-150s created by Livnitup from F-150 forum.
2013-2017 Fusion created by DanMc85 from 2GFusions forum.
2011-2018 Explorer's created by PlatinumOwner from the Explorer forum
2017 Ford Super Duty models F250, F350 and F450 created by EpicCowlick from Ford Trucks forum.
3. Related threads on enthusiasts forums
FORScan - software to enable/disable features in your truck - Ford F150 Forum - Community of Ford Truck Fans
2GFusions HOW TO: FORScan - Modify Module As-Built Data
Ford Trucks FORScan Spreadsheet
4. Official resources
Motorcraft - Module As-Built Data (returns factory data by VIN)
5. Other resources
Sync 3 APIM Programming
Love this information big Fatty to learn with. Credit to you. Thanks
Sharing each other for improvement!!
