FORScan Lite Beta for Android
Automate wrote: That's how I thought it should work but it is not how my Android 0.9.3 install is acting. Do I need to make a video?
Either a video, or exact sequence of actions (from clean install) to reproduce the problem would be really appreciated (because we tried to reproduce the problem and were unable).
Angela386 wrote:Application crashes when attempting to access the Table, Dashboard, or Graph options when in Live Mode. Options will load in Demo Mode, but crash when in live mode.
This bug is fixed, fix will be included in v0.9.5
Automate
Post by Automate »
It does not do it for all PIDs. It will do it in demo mode so the steps are below.
Steps:
Fresh install of 0.9.4
Go to Settings and set Measurements to Imperial.
Run in Demo mode select MY 2002
Go to Table and the configure PIDs page.
Select the EATC module.
Select any or all of the temperature PIDs (EXTTMPUN, FLOORTMP, INT_TEMP, PANELTMP)
Put the Table in live/run mode.
All of the temperatures show degree C
ducasp
Vehicle: New Ford Ka 2015 1.0 3cil TiVCT
Post by ducasp »
It is not really working for me...
Vehicle: Ford Ka 2015 1.0L TiVCT (the new ones made in Brazil that doesn't look like a Ka at all and that will sell as Figo in India)
Adapter: OBDLink MX Bluetooth
Phone: LG G3 with Android 5.0.1
First time connection, I could read the PIDs in Table mode, then entered the Errors section (ok, no errors), read vehicle/adapter information (found my vehicle correctly and adapter latency was 8ms). Entered dashboard, application crashed (no option to generate/send report)
All following times, after connection, if I try do anything other than read vehicle/adapter information, application will force close
I've tried clearing application data and cache and that did not help.
Application about says: FORScan Lite for Android v0.9.4 Kernel v2.2.3
Please let me know if there is anything I can do to gather more useful data for you.
Version 0.9.5 is released, first post of this thread is updated, including download link.
Comments:
Version: v0.9.4 Kernel v2.2.3
Phone: Samsung Galaxy Note II (GT-N7100)
Android Version: 4.4.2
ELM Device: OBDLink MX Bluetooth
Vehicle: 2006 Ford Explorer XLT 4.0L V6
Fixed in 0.9.5
ducasp wrote:It is not really working for me...
Same bug, fixed in 0.9.5
Automate wrote: It does not do it for all PIDs. It will do it in demo mode so the steps are below.
Steps:
Thanks, fixed in 0.9.5
ducasp
Post by ducasp »
Yes, that is correct, 0.9.5 works like a charm, tried two runs of about 20 minutes and no issues at all.
int0x13
Post by int0x13 »
I've upgraded to v0.9.5beta. In the upgrade i've lost my records. But i can restore the whole data+appli (v0.9.4beta) with Titanium backup. How can i export/import my records from v0.9.4 to v0.9.5? How can i migrate my datas into the new version? Thank you.
bufer
Vehicle: Focus MK3, 1.6 tdci 115 PS, 2011
Post by bufer »
Hi, I cant connect with my bluetooth adapter (none of bluetooth 0,1,2 settings works, v0.9.5) adapter is paired succesfuly - CAN OBDII (00:18:E4:D1:23:D4). Message "ELM not found. Try connection again" occurs. Adapter works with another apps (Torque, Scanmaster) without any troubles. Its some China clone of ELM 327 v1.4.
Thanks for any ideas...
fred08155
Post by fred08155 »
FORScan wrote:
fred08155 wrote:FSL files are saved to internal application storage, in documents folder.
I don´t have a documents folder. There are several folders like downloads, movies, pictures but no documents.
Can you tell me the exact path? Internal memory is mounted under /mnt/sdcard
I´ll try out new beta version soon. Doesn´t matter if i loose all data. Nothing important there yet.
jdub1981
Vehicle: 2013 Focus ST 2.0 Turbo
Post by jdub1981 »
Im sure its completely dependent on the phone but on my Note 4 it goes to storage/emulated/0/download/FORScan. Another path that gets younto the same place but using the Samsung Myfiles app: local storage/device storage/download/FORScan
Right, starting from 0.9.5 all user documents are saved to the standard Download folder. Prior to 0.9.5 it is not possible to access user documents outside of FORScan.
