Hello there
2016-06-13 my life to. I can help prolong the use of date?
It will have PCM-TCM as-built it?
Currently used in the MAZDA 2015 MAZDA 3 SKYACTIV 2.0
Thank you. Let me use such a good product
I've got the last version released, but I'm trying to acess this feature on my forscan, So this window where says "normal mode/engineering mode 1/ eng. mode 2" are not available to me.
Another question..
I'm trying to disable my passenger airbag via key ON/OFF only, but the only one result is all RCM system disabled, and the airbag's light won't turn off on the cluster.
NOTICE: The "Airbag Pass. OFF" light stays OFF after turn on the ignition.
Any help?
Another question..
Any help?
Hi FORScan,FORScan wrote:We are aware about this issue. RCM module requires special procedure to get access to the configuration, it is not implemented yet.radkor wrote: Unfortunately RCM (SRS airbag) configuration isn't working.
You have released a new version of your software and I see you have implemented configuration and programming procedure of RCM in Mondeo MKIV. However, I miss this functionality for Mondeo MK3. Is it going to be implemented in the near future, please?
You can generate new license when old one is expired, in the same way and free.ithinku wrote: Thank you. Let me use such a good product
Focus Mk2 has no central configuration. Only Mk3/3.5 have one. Please use ElmConfig for Mk2 configuration programming.kun87 wrote:I've got the last version released, but I'm trying to acess this feature on my forscan, So this window where says "normal mode/engineering mode 1/ eng. mode 2" are not available to me.
[quote="carbon"
You have released a new version of your software and I see you have implemented configuration and programming procedure of RCM in Mondeo MKIV. However, I miss this functionality for Mondeo MK3. Is it going to be implemented in the near future, please?[/quote]
We released configuration procedure for RCM of Mondeo Mk4 that has to be ran after Central configuration change. Mondeo Mk3 has
no central configuration, so it has no such a problem. What is the problem you are trying to solve, specifically?
I have added driver and passenger airbag curtains and I'd like to enable them in RCM module.FORScan wrote:...
kobusstrydom
- Vehicle: Ford Kuga 2013
Hi all
How do I get the engineering etc modes? I do not see that when I run ForScan.
Good morning!
I tried to use the central configuration on my tourneo custom but i only have this page.
The tourneo custom is not supported yet?
- File_002.jpg (75.52 KiB) Viewed 20530 times
- File_001.jpg (68.33 KiB) Viewed 20530 times
CrypticApollo
- Vehicle: Fiesta mk7
hi
trying to add configuration to mk7 fiesta
will not in options let me write to cc
dont undersand why ? read only ?
jc celular
- Vehicle: FORD fusion v6
HELLO, SOMEONE CAN HELP ME? I lowered my BUILT ON THE SITE WITH MY VIN MOTOCRAFT AND WHEN SHE TRY TO INSTALL IN MODULA A MESSAGE APPEARS THAT THE VEHICLE HAS NOT SOME MODELS, WOULD LIKE TO REALLY CAN PROCEED TO KNOW, I AM FROM BRAZIL FORD FUSION 2011 V6
