Hardware ID is generated from your computer hardware. The OBD device has nothing to do with the HW ID. You don´t need to be connected to your car.
Just start Forscan and go to the about dialog (steering wheel symbol) to see the hardware ID.
chirica george
- Vehicle: Ford focus, 1,6 taci 80kw, 2006
hy forscan, i have a extented licence, but dosent work.
i do all wright,load licence key,restart computer ,forscan.not work.
please help.
please help.
marian_S_petre
- Vehicle: Ford focus Ghia
Hello Forscan. Please create Paypall account for donation. Send my PM after. Thank you guys
If license key loading made with FORScan doesn't work, please add the key manually. 2 ways:
1. Find the license file using WIndows Explorer and double click on it, confirm adding to registry.
or
2. Open regedit (Windows Button on keyboard + R, type 'regedit', press enter), File->Import and select the license file.
Then restart FORScan
or
We have no donation and do not plan to have it, but anyway thank you for the offer, we appreciatemarian_S_petre wrote:Hello Forscan. Please create Paypall account for donation. Send my PM after. Thank you guys
Hi how can i get a extended licenses for forscan i need to update my pcm
chirica george
FORScan wrote:If license key loading made with FORScan doesn't work, please add the key manually. 2 ways:
or
Thankyou Forscan,now it works.
Is there PATS support in Forscan for MK4 Mondeo using extended licence? I am looking to program a new key fob
rainmakerr
hi!
i have 1 answer: how to use the PCM's programmation with my ford fiesta 1.4 mod 2008? i haven't lot of choices in the menu (only PCM PATS, i see that i can change and programme any keys, and module reset).
if anybody have the solution, i take it...
thank you for your help.
ps: great soft!
Seb
ps: great soft!
Seb
Sorry, not yet, but we are working on it....kevfal wrote:Is there PATS support in Forscan for MK4 Mondeo using extended licence? I am looking to program a new key fob
Sorry, we don't quite understand the question. Article about PATS programming is available here:rainmakerr wrote: i have 1 answer: how to use the PCM's programmation with my ford fiesta 1.4 mod 2008? i haven't lot of choices in the menu (only PCM PATS, i see that i can change and programme any keys, and module reset).
http://forscan.org/forum/viewtopic.php?f=6&t=839
However, PATS function for new Fiesta 2008 model year is not implemented yet ...
