Note about old/new Extended License keys (starting from FORScan v2.3.22)
Re: Note about old/new Extended License keys (starting from FORScan v2.3.22)
Post by tractmec »
ELECTRIC wrote: Fri Oct 01, 2021 12:47 pm I purchased a lifetime extended license a few years ago. on a Win 7 PC I am currently using a newer win10 PC and wish to transfer the license. My new hardware ID is F5034B2A-999B
Posting the Hardware ID on the open forum will not help and is not generally a good idea
If you still have the Win 7 machine operable and the Activation code saved either in your email inbox or you printed and filed a copy (best way to keep it safe) you will need to run Forscan in the windows 7 machine and use the "Uninstall Licence Key" button to deactivate the licence from the Win 7 machine at the activation server! Then reactivate the licence by running Forscan on the Win 10 machine and reactivate the licence on the Win 10 machine using the same activation code using Install Licence Key button inside the Forscan About page(both machines will need to have an internet connection)!
That Activation code is gold so do not loose it and if you have misplaced it or the win 7 machine is no longer operable, you will have to email the team at https://forscan.org/contactus.html with at least the Name you used to purchase, the email it was sent to, and even better, the Order number from your original licence purchase! If you have a copy of the activation code, emailing the team should not be necessary unless the WIN 7 machine is inoperable or the deactivation process fails for some reason!
Hope that helps?
ELECTRIC
Vehicle: FOCUS 1.6 CDTI 2007
Post by ELECTRIC »
I no longer have access to the win7 pC due to a hdd failure. I have e-mailed with full details as instructed.
anus
Vehicle: f250 superduty 6.2 gas 2011
Post by anus »
cant open free key
Post by tractmec »
anus wrote: Mon Oct 04, 2021 6:14 pm cant open free key
Install the key within Forscan using the "Load License key" button in the About Icon Page. See if this will help you: viewtopic.php?p=63970#p63970
sarahedmonds
Vehicle: 2011 Lincoln Town Car, 4.6L FFE
Post by sarahedmonds »
I have been trying to get the trial license for a couple days and it has not arrived in my email.
bazza250
Vehicle: ford mondeo MD 2015 ecoboost petrol turbo
Post by bazza250 »
where can i get a lifelong license ? the only options i see in products are 1 and 3 years
Post by tractmec »
bazza250 wrote: Mon Oct 11, 2021 12:06 am where can i get a lifelong license ? the only options i see in products are 1 and 3 years
5 Yr and Life Long licenses have been suspended until further notice with no Idea as to when they will be reinstated!
rcarbonaro
Vehicle: 2018 Ford F150 Limited
Post by rcarbonaro »
Has anyone had trouble opening trial version of extended license key?
I get a message saying that "the specified file is not a registry script. You can only import binary registry files from within the registry editor"
Post by tractmec »
rcarbonaro wrote: Tue Oct 12, 2021 9:41 pm Has anyone had trouble opening trial version of extended license key?
Try doing it through Forscan as in this Post viewtopic.php?p=63970#p63970
lukiprzy
Vehicle: Mondeo 2.0B 145, 2004
Post by lukiprzy »
When registering my license for two months, I entered my email address incorrectly and now I cannot obtain this license. What to do?
