Andyfocus
Post by Andyfocus »
bgeyer82 wrote: Tue Feb 05, 2019 11:51 pm Hello guys, hoping for some help here. I received my Extended License, and when I load it, it restarts, but when it comes back up, I don't have the confirmation that the license is still there. It also show an activation key. How do I get this to work? I have version 2.3.19. Thank you
what windows are you running ?
have you tried running forscan as admin (right click run as admin on windows 10 ) , if it remembers the id goto properties and click next to run this program as an admin on the compatability tab(windows 10 ) .
Wfo
Vehicle: Raptor 3.5L 2018
Post by Wfo »
I am having this same problem with windows 10. System is not recognizing extended license. Suggestions?
danou27
Vehicle: ford fusion 1.4 durashift 2004
Post by danou27 »
salut personnelement j'ai tout essayer pour mettre une licence etendue , rien a faire il ne me met qu'une version trial alor que la procedure a parfaitement ete faite , quelqu'un aurait-il une solution svp , aussi si une personne a la solution pour le boitier TCM pour ford fusion , le code erreur est p0949 tcm asm apprentissage inachevé merci
Vehicle: *** Ford ***
Post by f-wolf »
Wfo wrote: Sun Feb 10, 2019 3:12 pm I am having this same problem with windows 10. System is not recognizing extended license. Suggestions?
Just have a read here ... it may help you. :?:
http://forscan.org/forum/viewtopic.php? ... f=5&t=5775
RYM6746
Vehicle: Fiesta petrol 1.2 60Kw 2010
Post by RYM6746 »
Hi I'm sure this has been asked a 100 times already but I am new to forscan software. I have successfully registered my 2 month trial extended licence but I work in the motor trade and programmes many ford keys with the IDS. I prefer to use forscan as its a simpler proceess. How do I go about getting a permanent extended licence. I am happy to contribute financially for the service?
Thanks again for your help and the great software. :D
Post by f-wolf »
Hi there ...
Try this :
memberlist.php?mode=contactadmin
Ps ... You can renew your 2 month trial extended licence any time before or after it expires !
proudf150driver
Vehicle: 2017 ford f150 supercrew
Post by proudf150driver »
Hi I already re generated a extended licence , when it expires again is there a procedure to get a permanent extended licence or do I have to keep re generating one I'm not that great with computers I hope it's ok I posted this here thanks kindly
Andyfocus
Post by Andyfocus »
just do the same again and generate another licence when that one runs out ;) .
since writing this licences have been changed unsure if this still applies until i try it again myself.
wig073
Vehicle: ford v8 1999
Post by wig073 »
Well Andy if you can only respond with figjam comments then your not the person to answering questions
wig073
Post by wig073 »
Andyfocus wrote: Wed Feb 06, 2019 4:18 am
wig073 wrote: Wed Feb 06, 2019 3:34 am where is the about page to get the hardware id?
if you can not even find the simple things i think this is not for you , i would go to someone who knows what their doing .
Figjam
