Ford Kuga MK3 MY2021 As-Built Spreadsheet
Re: Ford Kuga MK3 MY2021 As-Built Spreadsheet
no idea?none?
Re: Ford Kuga MY2021 As-Built Spreadsheet
Hello, how do you activate TSR and honk on double lock?Tomo1971 wrote: Sat Apr 10, 2021 7:59 am Good to see others with the Kuga on here.
I have a UK Spec 2021.25 ST Line X 190 Auto AWD - With Tech Pack (Adaptive LED Headlights) / HUD.
Been a new user of Forscan but have used VCDS previously on some VAG cars - I have stuck to the plain text mods so far and have;
Enabled;
- Auto Lock at speed;
- Traffic Sign Recognition (using the camera)
- Changed the splash Screen
- Honk on Double Lock
- Voice Climate Control
I have not got adaptive cruise but hope to be able to activate Intelligent Speed Assist - I have using the plain text enabled all that I can see relevant, shows up on the Sync3 Screen under "Cruise" and gives options of 'Normal' or 'intelligent' but wont allow to change between them.
- Added Climate controls to Sync, incl Heated Seats and Steering Wheel Icon.
*ISA is listed as standard on ALL Kuga's in the UK, it is supposed to, as I understand use the traffic sign information to drop the speed of the cruise control to the prevailing limit, within a tolerance that the user sets in the Sync Screen.
I saw that this feature can also be activated but I do not know how to do it. "Driver fatigue warning"
Hi,NightlyWolf wrote: Wed Sep 01, 2021 7:07 pm
Added steering wheel control icon re-routed to Sync
Added windshield heating control icon on Sync
Added Sync seat heating control icon
I've had a Kuga Phev from 11.2023, Titanium X with the Tech Packages for a week now.
I would also like to have the above displays on the Sync3.4.
What changes would I need to make and where can I find them?
I have the Vgate FS USB adapter and forscan 2.6.1.
Many thanks for your help!
I'm a new Forscan user and owner of a new Ford Kuga PHEV. Your spreadsheet has been very helpful, and so far, I've enabled auto lock and perimeter alarm. Can you explain what this option exactly does?
IPC Settings Menu location Center Stack Cluster
I've also noticed that all alarm options in Sync 4 are greyed out. As far as I can see, I do have motion sensors; there is a small lens on the roof rack, left of the interior lights switch. Any chance to test/check them, ungrey options?
Thank you.
Thank you.
Managed to get alarm options ungreyed by setting this option
IPC Perimeter Alarm Guard Control Enabled
but no alarm sounded while moving inside a car. I'll try to take a pic of the lens in the roof panel for which I think is a motion sensor.
This one I didn't change
Here is a picture of possible motion sensor
