SHARKTEETH
- Vehicle: 10 f150 5.4
i have a 2010 F150 and i am looking for a the right cable to use. I found this cable and was wondering if it would work. It says 16 pin.
OBD2 to USB Port Adapter Cable, EEEkit 1M/3.3ft 16Pin OBD 2 Female to USB Male Port Diagnostic Tool Charger Adapter Cable Connector
any help would be appreciated.
Robert
Robert
Thanks, I did look around for them but they're both around 80 pounds shipped. I can get for a bit more a SVCI J2534 if I have to spend that muchfordsmax471 wrote: Sat Apr 25, 2020 11:40 amgoogle search or ebay searchr4w wrote: Fri Apr 24, 2020 2:06 pm Hi,
New here from UK and looking for the best adaptor on the UK market (USB) to use it with FORscan. Do you have any recommendations, from either eBay or Amazon or anything I can pay with PayPal so I can return if it doesn't fit my expectations?
Thank you!
OBDLink EX usb or els27v4 usb
darrenboddy
- Vehicle: 2019 F350 6.7L
New member! Hi~
I only have apple products (iOS) and it seems like everything I have seen on here is geared for Microsoft users. I purchased a (OHP ELMconfig FORScan OBD2 USB Adapter for Windows, Ford Diagnostic ELM327 Coding Tool with MS-CAN / HS-CAN Switch) but fear it will not work on my application.
Thoughts?
Thoughts?
For iOS, FORScan recommends OBDLink MX+. For Windows, OBDLink EX is your best option.darrenboddy wrote: Tue Jun 16, 2020 2:12 am I only have apple products (iOS) and it seems like everything I have seen on here is geared for Microsoft users. I purchased a (OHP ELMconfig FORScan OBD2 USB Adapter for Windows, Ford Diagnostic ELM327 Coding Tool with MS-CAN / HS-CAN Switch) but fear it will not work on my application.
Thoughts?
Kind regards,
Vitaliy
I bought the ELS27. Very happy with it. Worked first time, no switch needed, super quick in use, good build quality and cable.
Only downsides are high price and the fact the manufacturer seems not to have heard about airmail or DHL, and they only ship it by standard Russian postal service. I ordered from manufacturer's Ebay store and it took 5 weeks to arrive, presumably by boat, from St Petersburg. Much longer than than advertised delivery time. I would have happily paid extra for courier delivery.
geebee0316
- Vehicle: Escape 2.0L GTDI EcoBoost 2015
I own an OBDLink EX and I am going to order an MX+ soon for advanced options. I had some questions and their support team is so responsive and helpful. The build quality is really great as others have stated...vvmaks wrote: Mon Jul 13, 2020 7:08 pmFor iOS, FORScan recommends OBDLink MX+. For Windows, OBDLink EX is your best option.darrenboddy wrote: Tue Jun 16, 2020 2:12 am I only have apple products (iOS) and it seems like everything I have seen on here is geared for Microsoft users. I purchased a (OHP ELMconfig FORScan OBD2 USB Adapter for Windows, Ford Diagnostic ELM327 Coding Tool with MS-CAN / HS-CAN Switch) but fear it will not work on my application.
Thoughts?
Kind regards,
Vitaliy
I highly recommend supporting this company, I own a Snap-On Solus Edge, a Drew-Tech Cardaq Plus 2 and a bunch of Fluke and Fieldpiece equipment so I have had the good fortune of using high-quality tools and the OBDLink EX that I now own is top notch.richvollberg wrote: Tue Feb 25, 2020 4:06 am Update to my post above. The first EX unit I got had a bad USB cord. I contacted OBDLink and they sent out a new unit ASAP. It instantly conected and I had all the functions I was Looking For!.
Great Company and products. Working in the manufacturing field I understand that a Bad part gets sent out at times. Working on robots and PLC's we often order double the parts because the first one never works...![]()
I already did the mods I wanted like horn off and DRL to fogs, Global window up and down from fob. Bambi Mode. Mirror heater on with remote start.
This is a awesome tool and just added a couple thousand dollars value compared to other stock f-150 Sports XLT with the snow plow option.
Gary
Hello.
I have Viaken STN1170 V3.3.1 (ELM327 v1.3a) cable, will it be good for APIM update?
remy16
- Vehicle: Ford Transit MK5 EJAXML, 4EB 2,5 TD 73.6KW 1995
Hello FORscan community
I just tried the Obdlink EX USB module.
It is recognized by the PC (W7) but it does not recognize the 1995 Ford Transit 2.5l TD vehicle. The vehicle is equipped with a 16-pin obd socket and a 95V89J464 AA computer.
Could someone tell me the correct parameters to set for obdlink EX,
Thank you
Translated by Google
Thank you
- prise FDS ODB.jpg (108.18 KiB) Viewed 17272 times
- Vehicle: *** Ford ***
Your 1995 Ford Transit is too old !!remy16 wrote: Sat Oct 17, 2020 3:25 pm Hello FORscan community
Thank you
Your System
New System
adrianopery
- Vehicle: Ford Ecosport 2018
Hi guys, I would like to know if we have any other new option to use as Bluetooth device?FORScan wrote: Fri Mar 30, 2018 9:52 am Update 2019-12-11. Article updated as the following:
- Added reference to OBDLink EX
We are asked every day about adapter's choice. The problem is that there is no easy answer, as there is no ideal adapter that would fit best every specific case. In this article we have tried to address most important issues of the choice problem in most compact way.
Note: For professional work we would recommend to consider purchasing J2534 Passthru adapters that support Ford protocols. ELM327 family is recommended for amateur and semi-professional usage. This article reviews only ELM327 familty of adapters. J2534 Passthru devices will be addressed in a separate article.
1. Protocols
Table 1.1 - Ford protocols
OBDII name / Ford name OBDII jack pins Bus speed Bus min. response time How to detect SAE J1850 PWM / Ford SCP 2, 10 41600 bps 20...40 ms ISO9141 / Ford ISO 7 9600 bps 150...250 ms CAN / Ford HS CAN 6, 14 500 Kbps 0...20 ms / Ford MS-CAN 3, 11 500 Kbps 0...20 ms / Ford UBP 3 10400 bps 150...250 ms
Table 1.2 - Ford protocols by model generations
P - primary protocol (PCM)
S - auxiliary protocol (not mandatory for FORScan)
Generation SAE J1850 PWM ISO 9141 CAN Ford MS CAN Ford UBP Comment Ford 1996 - 2003 P S - - - Mazda 1996 - 2003 - P - - - Some models used SAE J1850 PWM as primary Ford EU, Mazda 2004 - 2009 - S P S - Some models used SAE J1850 PWM as primary Ford NA 2004 - 2009 - S P S S Ford, Mazda 2010+ - - P S - HS2, HS3 through MS-CAN
Simplest and quite reliable way to find out what protocols are supported in your car is to make a photo of the OBDII jack. Examples:
Focus Mk2 - only HS-CAN and MS-CAN Mondeo Mk3 after restyling - J1850, ISO9141, HS-CAN, MS-CAN
Table 1.3 - Ford protocols by adapters
Chip SAE J1850 PWM ISO 9141 CAN Ford MS CAN Ford UBP Adapter ELM327 standard X X X - - ELM327, Kiwi 3 ELM327 with HS/MS switch X X X X - ELM327 marked as Ford, Mazda compatible STN 1100 X X X - - OBDLink SX/LX STN 115x X X X X - OBDLink MX BT STN 1170 X X X X - ELS27 (old versions), Viaken STN1170 STN 2120 X X X X - ELS27 (new version) STN 2255 X X X X - OBDLink MX+ STN 2230 X X X X - OBDLink EX
2. Performance
Two parameters are mainly important for performance:
Min. interface respone time (minimal response time or ping) - minimal possible time from the moment request to adapter is sent to the moment the response from adapter is received
Max.interface baud rate - max possible data transfer baud rate between computer and adapter
These parameters directly affect connection time, parameter (PIDs) reading frequence, overall programming time
Table 2.1 - Adapters' performance
Adapter Chip Interface Min.interface
response timeMax.interface
baud rateComment ELM327 OHP HS/MS WiFi ELM327 (clone) WiFi 30-40 ms 38400 bps Unknown manufacturer - "good clone". Recommended only for iOS Kiwi 3 ELM327 compatible Bluetooth Low Energy 40 ms - Can be used only with FORScan Lite for iOS ELM327 HS/MS USB ELM327 (original) USB 0..2 ms 500 Kbps OBDLink EX STN2230 USB 0..2 ms 2Mbps Recommended for FORScan for Windows OBDLink SX STN1100 USB 0..2 ms 2Mbps OBDLink LX STN1100 Bluetooth - - OBDLink MX+ STN2255 Bluetooth 6..20 ms - Recommended for FORScan Lite for iOS, Android OBDLink MX BT STN115x Bluetooth 8..20 ms 115200 bps OBDLink MX WiFi STN115x WiFi - 115200 bps WiFi interface works unstable - it freezes and times out. Strongly not recommended! ELS27 v3 STN2120 USB, Bluetooth 0..2 ms USB, 20 ms BT 8 Mpbs USB Viaken STN1170 USB STN1170 USB 0..2 ms 2 Mbps Last versions of this adpater have buggy firmware 4.3.x. Recommended to downgrade to stable 4.1.1 or upgrade to stable 4.5.1 Viaken STN1170 BT STN1170 Bluetooth 20..30 ms 38400 bps Uses cheap BT chip so may freeze on some cars. Not recommended
Overall system performance can be easily estimated by adapter's performance and bus parameters as the following:
Overal min.response time = Min. adapter response time + Min.bus response time
Overal baud rate = MIN ( Adapter max. baud rate / 2, Bus baud rate)
3. ReliabilityExamples:
Two things are important for reliability:
- quality of the adapter. Not original adapters in general case have lower quality than original ones. We will create a dedicated article about so-called "clone problem".
- type of interface. The fact is that wireless interfaces used in ELM327 family of adapters are much less reliable than USB interface. And this problem is actual not only for "clones", but also for "original" adapters (OBDLink MX WiFi and Viaken VScan Bluetooth are most obvious examples).
So in general case we recommend to use USB for Windows version of FORScan, where it is possible. BT and WiFi devices are only recommended for mobile platforms (iOS and Android).
Also, important note about adapters with mechanical HS/MS switch: in addition to the fact it is not very convenient to switch it manually, it may be not possible to perform some operations with this type of adapter. If some operation requires a simultaneous access to both HS and MS (so FORScan needs to access some module(s) on HS CAN bus and, at the same time, other modules on MS-CAN bus), it cannot be normally executed using adapters with mechanical switch. Example: reading parameters (PIDs) in virtual module All, Module initialization subfunction in service functions "Remote keyless entry and Start".
4. Recommendations
Table 4.1 - recommendations on adapters
NO - not recommended for this platform
D - recommended for diagnostic: read PID, read/reset DTC, simple service functions
C - recommended for configuration: write configuration parameters to modules, complex service functions
P - recommended for programming: complex configuration, firmware update (only for CAN )* - can be modified for MS-CAN support as described here.
Adapter FORScan for Windows FORScan Lite for iOS FORScan Lite for Android OBDLink EX D, C, P NO NO OBDLink SX D, C, P* NO NO OBDLink LX D (if MS-CAN is not required) NO D (if MS-CAN is not required) OBDLink MX+ D, C D D OBDLink MX BT D, C NO D OBDLink MX WiFi NO NO NO ELS27 v3 D, C, P NO D Viaken STN1170 USB D, C, P NO NO Viaken STN1170 BT NO NO NO
5. Links to original adapters
All of these adapters were tested by us.
5.1. OBDLink product line: https://www.obdlink.com/
5.2 ELS27: http://els27.ru
5.3. Viaken: https://viaken.pl/pl/polski-elm327-v3-f ... -2014.html
Note: actually, all what we write about Viaken adapter is related to older version (v1 or v2, in black case). We had no chance to test their v3 version yet.
An updated list!
