ADD CLIMATE
Kolony648
Vehicle: Ranger 3.2WT/200hp,2016
Re: ADD CLIMATE
Post by Kolony648 »
niborc43 wrote: Sat Aug 05, 2017 9:20 am hi, when you carried this out were the temp zones in reverse?
Ive just done this same upgrade and the temp zones are the wrong way round.
Just wondering if yours was the same.
Your are fixed this problem or not please tell me for solution
Antiwomaagnot
Vehicle: Ford Fiesta 1.0 Ecoboost 140 ST Line
Re: ADD CLIMATE
Post by Antiwomaagnot »
CoD21 wrote: Thu Aug 27, 2020 8:39 am
Salva wrote: Mon May 11, 2020 5:08 pm I did this on my Fiesta Vignale 2019.
Apim
7D0-04-01 xxxx xxx0 xxxx (2 before modification)
7D0-01-02 xxxx x0xx xxxx (4 before modification)
That works perfect, i have surround option and nav on ipc/small screen distance and directions are goods.
do you have the buttons on sync screen? i did that but buttons dont show up
When changing these values , a master reset is required for changes to take effect
here all the documentation for the apim
https://cyanlabs.net/ford-apim-asbuilt-db/
tommcgov1
Vehicle: Mondeo Mk4 1.8 TDCI
Re: ADD CLIMATE
Post by tommcgov1 »
Hello 12VoltWill, can you tell me the wiring that needs to be changed, Focus UK model with factory sync 3 and dual auto aircon.
Have enabled it on the sync3 screen but as most people report the driver becomes the passenger on the sync touch screen.
Any help gratefully received.
KR
Tommgov
quote=12voltWILL post_id=17112 time=1505953145 user_id=51781]
I've done quite a few of these upgrades from Sync2/MFT to Sync3 and when the climate controls are backwards it's actualluy in the wiring.. There are 3 wires that need to be moved from one of the bezel harnesses to the other. I will try to post the solution tomorrow.
[/quote]
Jonni Pakpahan
Vehicle: Fiesta 1.6S
Re: ADD CLIMATE
Post by Jonni Pakpahan »
Cosmicbase wrote: Fri Jan 19, 2018 7:14 am OK thanks a lot. I will try it and give you a response.
can you help me
when i have a call no sound hear
THanks
sbt74
Vehicle: 2017 mondeo 2.0 tdci 150hp
Re: ADD CLIMATE
Post by sbt74 »
hello
I see you fixed some of the problems i have on my 2017 mondeo. Can anybody help me please?
I was testing my forscan and stupid me enabled many many things and than many many things didnt work ofcourse. I have fixed most of them but having problem with climat control. Everything works on the hard buttons but on sync3 i cant see nothing i do on buttons. climate is off on everything.
Also having problem with upper buttons on steering wheel. The ones that control dashboard. the left side controls now the center dash and the right buttons controls the left side of dash. Also the clock doesnt show on sync3 screen.
If anybody would have any idea what to do please help me.
best regards from Slovenia
Roman
thanos13
Vehicle: Fiesta,1.5 TDCI ,120HP.2018
Re: ADD CLIMATE
Post by thanos13 »
Hi, i managed to activate climate controls to sync3 screen using the drop down menus of forscan. Everything seems to work fine but i will test it tomorrow on my way to work. Does anyone knows anything about negative side effects after activating climate control on sync?
teosorin
Vehicle: Kuga Vignale 2020, 2.0L Diesel, 140 kW / Mustang Mach-e AWD
Re: ADD CLIMATE
Post by teosorin »
thanos13 wrote: Wed Feb 03, 2021 8:42 pm Hi, i managed to activate climate controls to sync3 screen using the drop down menus of forscan. Everything seems to work fine but i will test it tomorrow on my way to work. Does anyone knows anything about negative side effects after activating climate control on sync?
How I can activate the climate control on Kuga MK3 2020 with Sync 3 vers. 3.4?
Thank you!
domekrap
Vehicle: Ford Kuga Vignale 2018
Re: ADD CLIMATE
Post by domekrap »
Who knows how it should be set to display everything on the sync panel. now is like this
Climate Control Repeater Disabled
Climate Control Strategy Europe
Climate Control Type Manual
Climate Domain Enabled
Climate Icons - Mode Disabled
Climate Icons - Recirc Disabled
Climate Overlay - Dual Disabled
Climate Overlay - Max A / C Disabled
Climate Overlay - Max Defrost Disabled
Climate Overlay - Power Disabled
smartguy69
Re: ADD CLIMATE
Post by smartguy69 »
sbt74 wrote: Mon Feb 01, 2021 5:25 pm hello
Roman
You can downloaded your original as built file and then just upload it to the car.
https://www.forscan.org/forum/viewtopic.php?f=16&t=4393
Point No. 5
nicwilson
Vehicle: Ford Focus RS Limited Edition 2018 350HP
Re: ADD CLIMATE
Post by nicwilson »
I have tried to add the climate to my Ford RD LE 2018 Sync 3.4 and it simply does not work due to checksum error warnings. Forscan states not to worry about checksum as Forscan calculates the checksum for you but it does not. I also read to clear the last two digits to 00, but that does not work either, no matter what a checksum error warnings occur. Next I saw a thread that showed how to calculate the checksum and gave an example, testing the example on a hex calculator gave me the same value they showed, so then i tried it on this climate change, and entered the new value on the last two digits, but once again checksum error on write.
it maybe that is updates the checksum on write, but that is certainly not clear, and not a very good design if it does.
so how are users here getting this to work, or calculating the checksums, or as said above does this occur on write, disregarding the error.
Cheers
Nicw
