ADD CLIMATE
curtis kelly
- Vehicle: 2015 ford f150 5.0
ADD CLIMATE
JUST UPDATED FROM SYNC 2 TO SYNC 3 WANT TO ADD CLIMATE CONTROL TO RADIO ANYONE HAVE THE CODES THANKS
Re: ADD CLIMATE
I was trying to find this information as well. If anyone knows this and could share it would be very much appreciated!
Re: ADD CLIMATE
Try this:
7D0-01-02 xxxx x2xx xxxx
and 1 of the following:
7D0-01-01 xxxx xxx3 xxxx - Dual Zone & HD radio avail
7D0-01-01 xxxx xxx2 xxxx - Dual Zone & HD radio not avail
Re: ADD CLIMATE
Thanks for the info!
Below is what worked for me. My value before the change was a 5.
7D0-01-02 xxxx x3xx xxxx
Thanks again.
Thanks again.
Re: ADD CLIMATE
hi, when you carried this out were the temp zones in reverse?
Ive just done this same upgrade and the temp zones are the wrong way round.
Just wondering if yours was the same.
Nitemare
- Vehicle: Ford Focus RS 2017 2.3L
Re: ADD CLIMATE
Any solution to the issue of driver/passenger controls reversed for UK cars??
12voltWILL
- Vehicle: F150, 5.0L v8/285HP, 2015
Re: ADD CLIMATE
I've done quite a few of these upgrades from Sync2/MFT to Sync3 and when the climate controls are backwards it's actualluy in the wiring.. There are 3 wires that need to be moved from one of the bezel harnesses to the other. I will try to post the solution tomorrow.
Nitemare
Re: ADD CLIMATE
Cool!!! Cheers.12voltWILL wrote:I've done quite a few of these upgrades from Sync2/MFT to Sync3 and when the climate controls are backwards it's actualluy in the wiring.. There are 3 wires that need to be moved from one of the bezel harnesses to the other. I will try to post the solution tomorrow.
Re: ADD CLIMATE
Anything more on a solution to this please had the option on my sync 2 but chuck norris on sync 3 dissapointed12voltWILL wrote:I've done quite a few of these upgrades from Sync2/MFT to Sync3 and when the climate controls are backwards it's actualluy in the wiring.. There are 3 wires that need to be moved from one of the bezel harnesses to the other. I will try to post the solution tomorrow.
Re: ADD CLIMATE
Just what I was looking for, thanksbrheberle wrote:Thanks for the info!
Thanks again.
