Hello it is possible to display the digital speed in the IPC as with the GT350 this has the possibility to display it, the normal GT not.
Thanks for Help
Digital Speedometer in Mustang 2015 GT
Blackpearl
- Vehicle: Mustang 2015 5.0V8
Re: Digital Speedometer in Mustang 2015 GT
It's not possible unfortunately unless you add the GT350 cluster or the new 2018 cluster, if you look on other forums they've done the conversion on a UK spec gt
I enabled it on my 2016 Fusion Titanium.
Here is what is changed on my car. As always it might not be the same on a different model so I take no responsibility if this messes anything up. It probably wouldn't hurt to see what happens as you can always change it back.
Digital Speedometer Gauge:
720-07-01 (2015+ MY) xxxX xxxx xxxx
(IPC)
0 (Disabled)
1 (Enabled)
(IPC)
0 (Disabled)
1 (Enabled)
The mustang ipc firmware doesn't support it which is absolutely crazy! The GT350 and 2018 digital dash does but not 15-17
I've tried that code before you just get an invalid selection message on forscan lol
That is crazy.
