Hi, I'm investigating adding front sensors to my car, however when programming the APIM no matter what option I tell the APIM it's got I still only get the rear sensor image for the overhead distance display, not both front and rear.
I've tried the following:
7D0-02-02 x*xx xxxx xxxx where * = 3 for flank guard
7D0-02-02 xxx* xxxx xxxx where * = 2 for front and rear
I'm going to try and tell the PCM that it's got front and flank guard to see if that changes the image and also add it to the IPC but surely this shouldn't matter if I've told the car it has the above with front the image of the front sensors should come up even when it's not installed yet or am I wrong?
