Auto-lock and auto unlock enable 2014 interceptor sedan
Faldo
Vehicle: 2014 police interceptor sedan 3.7
Post by Faldo »
Has anyone been successful in getting auto-lock and auto-unlock to work on an interceptor sedan? I enabled the feature with Forscan (it also shows up in the instrument cluster) but the locks won't engage. I have the remote lock, and remote start enabled and both of those are operational, so I thought auto-lock would work. I followed the Ford programming to enable or disable auto-lock:
Close all the doors.
Make sure that the ignition switch is in the ’OFF’ position.
Turn the ignition switch from ’OFF’ to ’RUN’.
Press the power door lock ’UNLOCK’ button three times.
Turn the ignition switch from ’RUN’ to ’OFF’.
Listen for the vehicle’s horn to chirp one time.
That worked fine, I got the one horn chirp but then it says to:
press the power door lock ’UNLOCK’ button one time to command the RAP module to toggle the auto-lock/relock feature ON or OFF. It's supposed to honk once for disabled and a chirp and a honk for enabled but nothing happens. Any ideas?
TimFor
Re: Auto-lock and auto unlock enable 2014 interceptor sedan
Post by TimFor »
No idea what interceptor is. But for Focus there are 3 auto lock settings and all must be enabled: general auto lock feature, available for customer to program, set in the car (same as your locks). Since Focus Mk2 doesn't have CC, they are found in GEM.
