programming: missing BCM options for Mazda 3 BL
olgierdw
Vehicle: Mazda3 BL 1.6 2010
Post by olgierdw »
I wonder if I can add to FORScan DB these settings for my vehicle type?
Details below:
I use FORScanSetup2.3.24.beta
My car is recognized: Mazda Alexa/Mazda3 Z6 1.6L, VIN: JMZ.......47729
Vehicle:
Model: Mazda Axela/Mazda3
Engine: Z6
Capacity: 1.6L
Generation: Other
Transmission gear: Manual
VIN: JMZBLxxxxxxx47729
BCM/GEM - Body Control Module / Generic Electronic Module
Part number: BCW8-67560-
PROBLEM:
In BCM module is very limited number of options to modify.
I look for Lighting System Personalization - The auto light system sensitivity can be adjusted.
here is URL to procedure: http://www.mazda3tech.com/lighting_syst ... e-734.html
here data about procedure from URL:
M-MDS display: Autolamp On Setting
Function: The auto light system sensitivity can be adjusted
Initial setting: Standard (Except Japan)
Setting content: Extra Low (Except Japan) / Low (Except Japan) / Standard (Except Japan) / High (Except Japan) / Extra High (Except Japan)
Control unit: BCM
Is there a tool to migrate/convert official IDS software DB into FORScan DB?
