My ford focus electric appears to output a valve into the log at about 5ms. This issue is I quickly run into CSV files that are giant and hard to process. For example excel will only let you graph data that has 32,000 rows.
So I was trying to see if there was any way to adjust the record/logging rate. I would love to be able to select 1 second intervals or anything in between. This way I can record a long drive or a complete charging session without quite as much data processing when I get done.
Limit Logging Rate
Re: Limit Logging Rate
At this moment there is no such possibility, except post-processing (create and app or script to process the CSV and remove "unnecessary" data).
In the future we will try to add such a setting.
