Hello, is it possible to reset the fuel additive system on a Ford C-Max 2.0l?
Is there a how to?
Regards
Reset fuel additive system?
Re: Reset fuel additive system?
Yes, you can do it. There are 2 types of operations with fuel additive in FORScan:
Refill the FAT - used when the Fuel Additive Tank is refilled (right after the refill itself
Fuel Additive System Prime - used if module was replaced or any of the pipes were disconnected
Functions are quite simply, just follow FORScan instructions.
