Page 1 of 2
help with ford sync 3 apim firmware programing
Posted: Tue Jan 07, 2020 2:42 pm
by performanceisland
So i took a chance and it errored out, now i have dead apim, tried reset, have not tried ids programmable module installation yet, as i do not have a sync 3 car here, but wondering if there is anything else i can try with forescan? I noticed the last two current versions are not showing, see pics. there doesn't appear to be an option to program one thing at a time either.
PS any update on a full working version for firmware or is that still a long time away?
Re: help with ford sync 3 apim firmware programing
Posted: Sat Jan 18, 2020 6:35 pm
by brad2388
Did u get it?
I have a failure too it stopped in the middle.
What i did was just write the illumination file by itself. It took it ok and problem solved.
Posted: Tue Jan 21, 2020 12:18 am
ill try that also having problems getting files, i also think I am using an older beta of 2.4.0 mine says its test 20190909, someone mentioned there is a newer version, can someone email that to me on here or give me a link to it? that might be part of my issues.
the illumination file is which one? in my version of forescan it doesn't say illumination anywhere, the two options for ECU configuration are base and sound.
Posted: Wed Jan 22, 2020 7:02 pm
by Andyfocus
Posted: Wed Feb 05, 2020 4:07 am
by JoshArmour
I’m also wanting to do this, and I have the obdlink ex and have purchased a lifetime extended license. Before I attempt this, I’d like to know that someone has done it.
Posted: Wed Jun 03, 2020 7:35 am
by LaForge
APIM Upgrade is at this point NOT supported by Forscan 2.40.X
You have to read the text from Forscan team which is deployed with the file.
It clearly says NO APIM Update.
You have to wait until its official supported in another Beta or the final Version 2.40
regards
Karsten
Posted: Wed Jun 03, 2020 9:30 pm
by lordwader
I have strange situation, trying to update firmware of APIM according cyanlabs description:
1. download
2. test run SBL
3. PROBLEM - should be program, but this button is invisible after above procedure
is it some new bug? any ideas how how to solve problem?
Posted: Thu Jun 04, 2020 11:30 am
by Ghano38
Master reset.
Posted: Thu Jun 04, 2020 8:25 pm
by lordwader
Ghano38 wrote: Thu Jun 04, 2020 11:30 am Master reset.
what You mean??
Posted: Fri Jun 05, 2020 4:58 pm
by Ghano38
In Sync menu you can make a master reset of all settings.
