Ford Focus mk2 ASR, ESP issue after odometer write
pjung
Vehicle: Ford Focus Mk2, petrol 2.0, 107 kW, 2005
Post by pjung »
Hi All,
I have a Ford Focus MK2 2.0 l petrol car. I tried for curiosity to write the odometer on my car, I was able to increase the km value, but not to decrease it from the "odometer write" menu. Than I tried to use the menu under IC programming, called "write odometer value in km" or so. As I wrote the former value from this menu, the decreasing also didn't succeeded, but many problems came instead of.
The problems I got:
- auxiliary heater failure (the car isn't equipped with such that)
- EPB malfunction (the car isn't equipped with such that)
- a lot of configurations altered (chime beeping continuously in reverse gear; speed warning chime at 120 km/h; the 5 km/h offset is gone; the engine is cutting off at 7000 RPM - normally it could run up to 8000 RPM - ; I got an extra menu item, "hill launch assist", which would be nice, if it would work)
- And the worst of all, the ESP and ASR are completely gone. It doesn't shows up like a failure, it is invisible for the system. Even the check light won't show up when I set the car on ignition.
I tried to reprogram all the systems with IDS, but it doesn't helped, I could only get rid of the reverse gear warning, the auxiliary heater, and EPB warning (I set the last 2 to unequipped). The other nasty problems are still there, and the car won't recognize that she has an ESP and ASR.
I used the newest version (2.3.29) of FORScan, with VXDIAG VCX nano, for the odometer write procedure. The car is a Ford Focus MK2 2.0 l petrol version, with 145 HP / 107 kW, from 2005, engine code is AODA, the ECU is a Visteon ESU13 5M51-12A650-SD 3CGD.
Could someone please help me with this issue? With some AS built data, or maybe with a factory default flash image for the systems in the car, or something, which can revert those to the original state.
And I think this is a software bug, which should be solved, or the function should be removed or disabled, because it can cause major problems.
Andyfocus
Re: Ford Focus mk2 ASR, ESP issue after odometer write
Post by Andyfocus »
as stated in all the release notes , odometer write can only be increased , their may even be a warning before writing it too.
pjung
Post by pjung »
Andyfocus wrote: Sun Feb 23, 2020 10:42 pm as stated in all the release notes , odometer write can only be increased , their may even be a warning before writing it too.
Yes, but there was the option to decrease, and you get a warning almost before every write operation, and this operation seemed harmless...
Andyfocus
Post by Andyfocus »
pjung wrote: Sun Feb 23, 2020 10:49 pm
as far as i know their was never an option to decrease the milage for legal reasons and to not allow clocking of cars etc where people lower the milage of of them.
pjung
Post by pjung »
Andyfocus wrote: Mon Feb 24, 2020 1:42 pm
This answer isn't helpful with the main topic. But there was an option "write odometer value in km", which is legal under certain circumstances. By the way, increasing can be also illegal, but in this topic I asked for how can I fix the ESP and ASR which are gone, and the other modified parameters.
Don Ridley
Vehicle: 2016 Transit Connect
Post by Don Ridley »
Have you tried loading copies of your saved files? This circumstance shows why it is wise to save every file, not just the one you think you are changing.
Your fallback can be to get the files off the Motoecraft site and reload the ones that seem to be affected (IPC, BCM etc). The question is do you load and test one by one or do you do all of the at once? I don't know.
pjung
Post by pjung »
Don Ridley wrote: Mon Feb 24, 2020 2:53 pm Have you tried loading copies of your saved files? This circumstance shows why it is wise to save every file, not just the one you think you are changing.
I haven't saved, because I did not modified AS Built data, and I don't expected that this will cause a lot of trouble.
The Motorcraft site can be a solution. I think it is more safe to load and test them one by one. I tried to reprogram every available module with IDS (including ABS), but this hasn't solved the problem.
pjung
Post by pjung »
I got the AS-Built data from the https://www.motorcraftservice.com/AsBuilt site.
It is the following:
Module Build Data (As-Built)
VIN WF*******0
Tear Tag 1535
Vehicle Data 40EC FFFF FF29
Module Information Found
When prompted, be sure to save or copy the file to the following IDS directory:
c:\Program Files\Ford Motor Company\Calibration Files
PCM Modules
PCM 1 FF52 FFFF 0363
PCM 2 4110 48FF FFA9
PCM 3 7841 FFFF FFC9
PCM 4 FFFF FF26 265D
PCM 5 2020 3727 FFB2
PCM 6 FFFF FFFF FF11
PCM 7 FFFF FFFF FF12
PCM 8 FFFF FFFF FF13
PCM 9 FFFF FFFF FF14
BCE Modules
Module Address Instructions
720-01-01 C0C0 1101 BB
720-02-01 5757 5757 57DD
720-03-01 5746 3033 5883
720-03-02 5847 4344 3385
720-03-03 3541 3734 3947
720-03-04 3030 8E
726-01-01 640C 0006 A5
726-02-01 2704 70CB
727-01-01 0200 083A
727-02-01 5746 3033 5889
727-02-02 5847 4344 338B
727-02-03 3541 3734 394D
727-02-04 3030 94
730-01-01 5746 3033 5891
730-01-02 5847 4344 3393
730-01-03 3541 3734 3955
730-01-04 3030 9C
730-02-01 0014 3246 642A
730-02-02 0009 1932 5AE9
730-02-03 A5AC B7BF CACD
730-02-04 8C96 A5AF CF82
730-02-05 6C78 8B97 ED31
730-02-06 5E6A 7D96 ED07
730-02-07 4A4A 5869 851A
730-03-01 0014 3246 642B
730-03-02 000E 1932 5AEF
730-03-03 969D A8B0 BB83
730-03-04 656F 7E88 CFE7
730-03-05 5C68 7B87 EDF2
730-03-06 4753 667F EDAC
730-03-07 4040 4E5F 7BE9
730-04-01 0014 3246 642C
730-04-02 000A 1432 5AE7
730-04-03 939A A5AD B875
730-04-04 616B 7A84 CFD8
730-04-05 4B57 6A76 EDAF
730-04-06 3A46 5972 ED79
730-04-07 3838 4657 73C2
730-05-01 0845
737-01-01 46BB 0180 C2
737-02-01 5746 3033 5899
737-02-02 5847 4344 339B
737-02-03 3541 3734 395D
737-02-04 3030 A4
760-01-01 5746 3033 58C1
760-01-02 5847 4344 33C3
760-01-03 3541 3734 3985
760-01-04 3030 CC
760-02-01 006A
End of information
How can I use this data to revert everything back to factory settings? And I also downloaded the .as file, which is an XML formatted file. Can I import it somehow?
Don Ridley
I have never used the Motoecraft files and I don't know the exact procedure. This question has been answer many times on the forum so you should find it with a search.
pjung
Post by pjung »
With the Motorcraft AB file it was pretty easy to fix the problem. FORScan can open it, and is able to use most of the blocks from it. After applying the original AS-Built data, everything works fine, as before the problem. :)
There was only differences between the IPC configurations.
Thanks for the help!
