DTC U3000:41-48 General Checksum Error
Storkpkp
Vehicle: F-150 Lariat, 3.5L ecoboost, 2015
Post by Storkpkp »
After flashing my firmware on my APIM I am getting this DTC. I don't see any adverse affects, but I was wondering if anyone knew more about this or had seen it.
Re: DTC U3000:41-48 General Checksum Error
Storkpkp wrote: Sun May 24, 2020 6:44 pm After flashing my firmware on my APIM I am getting this DTC. I don't see any adverse affects, but I was wondering if anyone knew more about this or had seen it.
after the flashing
did you restore APIM As Built data :?:
Storkpkp
Post by Storkpkp »
I just did that. It was seeing it as SYNC 1, so I had to write some values to get it to recalculate checksum. Then it allowed it to see it right. I then reloaded from my saved values. Is that the part where I am messing up. Do you have to manually write them?
Andyfocus
Post by Andyfocus »
if you have changed the original as built due to having modded the car then you dont load as built , you have load up the modded as built that you should have saved when you made the mods .
Storkpkp
Post by Storkpkp »
Um, wut?
zjohnny
Vehicle: MONDEO MK5 TITANIUM 150CV DIESEL
Post by zjohnny »
I have same problem, how can I solve? I have upgraded from sync2 to sync3
zjohnny
Post by zjohnny »
I have rewritten without modifies as-built, force restarted my module but error renaming! I have old style IPC version can it be that?
elpamyelhsa
Vehicle: Ford Ranger XLT MY17 PX2 w/Tech Pack
Post by elpamyelhsa »
Its a fimrware checksum error, this means you have a corrupt module firmware. Make sure you have a battery charger plugged in and "force" program the module to the same version as it currently is. Then the DTC should clear.
the-drew
Vehicle: 2017 f150 2014 transit connect 2012 transit conn
Post by the-drew »
I have the same DTC Code: U3000 - - Supervision Software Failure when you say force program do you mean the asbuilt data or something else?
Never mind i found it viewtopic.php?f=13&t=18751&start=10#:~: ... %20enabled.
