pid identification
william
pid identification
Post by william »
I'm not sure what the two pids I highlighted in the screenshot monitor, I think they are pressure control valve and volume control valve for the high pressure pump.
Could someone confirm or correct my guess.
cheers.
Untitled.png forscan.png (91.3 KiB) Viewed 5416 times
08 mk4 mondeo 2.0 140 bhp
Re: pid identification
Yes you are right.
PCV PWM - pressure control valve pulse-width modulation duty cycle - a signal that module sends to PCV.
VCV PWM - volume control valve pulse-width modulation duty cycle
The term duty cycle describes the proportion of 'on' time to the regular interval or 'period' of time; a low duty cycle corresponds to low power, because the power is off for most of the time. Duty cycle is expressed in percent, 100% being fully on.
Source: https://en.wikipedia.org/wiki/Pulse-width_modulation
Good illustration of duty cycle: http://d32zx1or0t1x0y.cloudfront.net/20 ... 02_lrg.jpg
We will correct the descriptions in our database to make it more informative.
william
Post by william »
Thanks for the confirmation and info about duty cycle, seems there's a few controls on the mondeo that use duty cycle.
