FORScan closing up
FORScan closing up
Hi.I need help with Foascan aplication.I downloaded and instaled also add license without problem.But I get one big issue when I open forscan then shows a window with message problem with aplication forscan.exe.When I trying to error raport to microsoft Forscan closed up itself.When i choose not send it's same problem closing program.I'm using Windows XP Sp3 .Tryed on 2 pc and the same result.If enyone heave simillar problem and resolve it I will be very gratefull for info.BR
Re: FORScan closing up
Does it crash if you don't install an extended license?
Do you use Galletto app?
Yes it crash iven without licence.And yes I heave Galleto v54 is this bad?
Solved galletto unnistalled.Thanks
This is known problem - Galletto installs its custom FTDI driver (ftd2xx.dll) into the Windows system directory. FORScan tries to use this driver and the driver crashes. It is not necessary to remove Galletto, just copy "right" ftd2xx.dll to the FORScan folder (near the FORScan.exe). You can download it from the FTDi site or from our site:gumol77 wrote:And yes I heave Galleto v54 is this bad?
http://forscan.org/download/ftd2xx.zip
We do not include it in the distributive and also do not use static compilation because system driver may be newer or, vice versa, older (some clones use counterfeit FTDI chips that do now work with new drivers etc).
Thank You very much.BR
Dear FORScan i heave one more question I dont se any Service Procedures in my program.How I can enable?
answered in PM
