Hi
I can not put new injector codes to my mazda6 GH 2.0 diesel, what is strange i can change only exsisted codes, for example code from injector one i can put on injector two place, but when i try to put codes from new injectors it showing error and not let me change anything , any ideas? (checked on few versions of sowtware and two cars 2006 and 2008 year)
Mazda6 injector coding problem
Re: Mazda6 injector coding problem
Are you sure new injectors are from your vehicle? PCM may not accept injector codes if the injectors are from different engine.
Anyway, please send us FORScan logs as described on Contact Us page, for analyzing the problem.
As answered by email, after the log analysis, the assumption PCM doesn't accept injector codes from another engine seems to be correct.
