I have an OBDlinkMX dongle and use it regularly with Forscan.
I'm buidling an arduino to display some values from a mix of own sensors and the service (obd mode 22) sensors.
I have the pid for trans oil temp and engine coolant temp, but having trouble tracking down the rest.
Coolant is from OBD mode 01.
Trans is from Mode 22 (1E1C).
Is there a list of what PIDs forscan is using to get sensor values?
I'm mainly after:
- Cabin Temperature (Inside car temp)
- Ambient Temperature (sensor in-front of radiator, not MAF)
- Boost Pressure
- Intercooler temperature sensor (Sometimes known as IAT2 or Charge Air)
PID List
Audiomediocrity
- Vehicle: F250, 6.7 PowerStroke, 390 HP, 735 ft lb 2014
Re: PID List
did you find a pid list? this would be incredibly helpful
