Hi I’m new to forscan ( ext license) . My problem 2009 ford focus 2.0 tdci won’t crank ( immobilised light flashing) codes P1622 and B1681 . Can’t clear . Disconnected the 3 plug left hand side foot well and above to clean. Removed air filter and cleaned all earth points. Tried the spare key but still won’t crank . Please help any ideas would be greatly appreciated many thanks Jason
Forgot to say brand new battery fitted
Focus 2009 immobilised light flashing
- 778AD43A-A05D-4D4E-B292-2DACDD280099.jpeg (45.43 KiB) Viewed 1152 times
- C7090AEF-B41A-4AE9-8E7B-D416226E07EA.jpeg (31.49 KiB) Viewed 1152 times
Re: Focus 2009 immobilised light flashing
Halo.I have a similar problem in kuga2009.After replacing the instrument cluster, I coded two keys.The car won't start.There are two mistakes>B1681 P1622-71.I think I mixed something up badly while initializing the modules
.The errors are the same as those of the colleague above.please help.
Regards Krzysztof
Regards Krzysztof
boosted_diesel
Did you do a pats system initialisation?
I was in „RKE programming remote opening and starting the keyless system“, I deleted and re-registered two keys,
then I went to the initialization function-
remote control function actuator
-electronic steering lock
-drive system control module
-2 or more
I chose everything because I didn't find what I mentioned, i.e. IC
-2 or more
Hello.
Thank you Forscan for your help.The problem was solved.I connected the old IC module,despite the various lights flashing I managed to remove the error code-P1622-71 he was the one who didn't let me start the car.after connecting the new IC and deleting the codes, the car starts.there is only an error in IC-B1681-60.but it doesn't bother me.Thank you
Top
Top
