Version is 1.2.5.
Tha adapter is the white WiFi. Timing looks ok.
Here's the log:
Code: Select all
11:48:43.296 [] Vehicle Thread initialized
11:48:43.318 [Ford Vehicle] OBDVehicle Thread started with id 54485244
11:48:43.318 [] Vehicle Thread started
11:48:46.841 [IP channel] Socket opened, result 1
11:48:46.860 [Comm Adapter] Adapter Thread started with id 54485244
11:48:46.892 [Comm Adapter] Profiling: 30 ms
11:48:46.945 [Comm Adapter] Profiling: 52 ms
11:48:46.945 [Comm Adapter] ELM327 detected!
11:48:46.985 [Comm Adapter] Profiling: 40 ms
11:48:46.985 [Ford Vehicle] Adapter found on IP 0A00A8C0, port 35000
11:48:46.999 [Comm Adapter] I'm finishing
11:48:47.010 [ELM327 Adapter] Adapter Thread started with id 54485244
11:48:47.170 [ELM327 Adapter] Profiling: 160 ms
11:48:47.202 [ELM327 Adapter] Profiling: 31 ms
11:48:47.249 [ELM327 Adapter] Profiling: 47 ms
11:48:47.297 [ELM327 Adapter] Profiling: 48 ms
11:48:47.348 [ELM327 Adapter] Profiling: 51 ms
11:48:47.382 [ELM327 Adapter] Profiling: 34 ms
11:48:47.427 [ELM327 Adapter] Profiling: 45 ms
11:48:47.464 [ELM327 Adapter] Profiling: 36 ms
11:48:47.509 [ELM327 Adapter] Profiling: 45 ms
11:48:47.549 [ELM327 Adapter] Profiling: 40 ms
11:48:47.595 [ELM327 Adapter] Profiling: 46 ms
11:48:47.595 [Ford Vehicle] Checking ping delay
11:48:47.642 [ELM327 Adapter] Profiling: 47 ms
11:48:47.683 [ELM327 Adapter] Profiling: 41 ms
11:48:47.714 [ELM327 Adapter] Profiling: 31 ms
11:48:47.744 [ELM327 Adapter] Profiling: 28 ms
11:48:47.773 [ELM327 Adapter] Profiling: 29 ms
11:48:47.820 [ELM327 Adapter] Profiling: 46 ms
11:48:47.864 [ELM327 Adapter] Profiling: 44 ms
11:48:47.910 [ELM327 Adapter] Profiling: 46 ms
11:48:47.939 [ELM327 Adapter] Profiling: 29 ms
11:48:47.979 [ELM327 Adapter] Profiling: 40 ms
11:48:48.025 [ELM327 Adapter] Profiling: 45 ms
11:48:48.029 [Ford Vehicle] Found PCM type: 0x130
11:48:48.092 [ELM327 Adapter] Profiling: 60 ms
11:48:48.142 [ELM327 Adapter] Profiling: 50 ms
11:48:48.418 [ELM327 Adapter] Profiling: 276 ms
11:48:48.542 [ELM327 Adapter] Profiling: 124 ms
11:48:48.803 [ELM327 Adapter] Profiling: 261 ms
11:48:48.978 [ELM327 Adapter] Profiling: 174 ms
11:48:49.069 [ELM327 Adapter] Profiling: 91 ms
11:48:49.080 [Ford Vehicle] Failed to find vehicle identification information
11:48:53.031 [ELM327 Adapter] Profiling: 39 ms
11:48:56.204 [ELM327 Adapter] Profiling: 161 ms
11:48:59.252 [ELM327 Adapter] Profiling: 36 ms
11:49:02.303 [ELM327 Adapter] Profiling: 39 ms
