engine speed synchronization state
william
Post by william »
forscan has a pid for engine speed synchronization state with values of yes or no.
Could someone explain what this pid is used for.
Thanks.
08 mk4 mondeo 2.0 140 bhp
Re: engine speed synchronization state
This parameter indicates if the CKP and CMP signals are in synchronization. Some reference (occasionally found using google):
http://www.autonerdz.com/cgi/yabb2/YaBB ... 1077376754
It is possible to catch the synchronization using very fast adapter (fast USB or J2534) in conjunction with special block mode that allows to retrieve data with very high rate (not available in FORScan v2 yet, although was available in v1)
william
Post by william »
Thanks for the information, when I searched google the only information I could find regarding engine speed synchronization was to do with gearbox.
Cheers.
