2014 F150 Audio Control Module
GGONZALEZ31
Vehicle: 2014 Ford F150
Post by GGONZALEZ31 »
Purchased a Ford F-150 with that had an aftermarket stereo. I want to put the original radio back, which I do not have. I recently was able to obtain the part number for the original radio that this F150 was equipped with. After purchasing a used replacement with the matching part number, it is not working. Any ideas as to what needs to be done to get this ACM to work.
rbentnail
Vehicle: 2013 F150STX 4x4 5.0
Re: 2014 F150 Audio Control Module
Post by rbentnail »
I think I'd start by comparing my ACM As-Built data with what is in there now using Forscan. Somewhere around here is a link where you can enter your VIN and get the As Built data for your vehicle.
try here -> https://forscan.org/forum/viewtopic.php ... ata#p59244
