Ford Scorpio 2.5TD 1998
scorpiovm
Post by scorpiovm »
Is there any support for 2.5TD with VM -engine and with newer Bosch injection pump with electronic control.
Trying to find out pump IQ before changing the pump seal.
I have also Scorpio 24V 1997 and with ELM327 Forscan reads some PWMs and ISO ABS.
But from this 2.5TD I can get only PWM-PCM.
Re: Ford Scorpio 2.5TD 1998
We can check this vehicle session in FORScan logs, and tell you if something is missing (and fix it, if something is missing). But we would not be too hopeful about pre-2000 vehicles, as computer diagnostic abilities were quite limited that time. Especially if we are talking about TD engine...
Instruction how to send logs:
1. Make sure FORScan is closed
2. WIndows Start button->All programms->FORScan->FORScan Log folder.
3. Folder with logs will be opened, you should see 2 files there: dump.bin and FORScan.log (may be more). Please zip them and email to the address specified on Contact Us page, or use PM function on this forum.
