I use ForScan 2.1.18 EML changed with this vehicle:
Vehicle:
Model: Mazda BT-50/Ford Ranger
Engine: WL-CD
Capacity: 2.5L
Year: 2007 MY
But I have a problem in the "sercice and procedures" I have no indications tab. What for? Procedures appears if the program detects a fault?
Thank you for your answers.
Have not service procedures
raymond973
- Vehicle: Mazda BT-50/Ford Ranger, WL-CD, 2.5L, 2007 MY
Re: Have not service procedures
Service procedures are different for every model. If no service procedures is displayed in your cases, it most likely means there is no ones implemented in FORScan for your model. Are there any specific procedures you expected to perform?
raymond973
Thank you for your reply.
I wanted to enter the programming of doors, egr valve, and programming the key buzzer.
When EML is on MSCAN I can not connect to the vehicle
Will look into this....raymond973 wrote:egr valve
Managing vehicle configuration is a subject of future developments.raymond973 wrote: I wanted to enter the programming of doors,
That's right, it should not - when you connect, HS/MS CAN switch must be always in the HSCAN position (FORScan should display a notification about it).raymond973 wrote:When EML is on MSCAN I can not connect to the vehicle
raymond973
Thank you very much for your response.
mikeluscher159
Program the key buzzer?
You mean program a new/replacement remote keyless entry fob?
You don't need FORScan for that, http://www.programyourremote.com/classi ... -5439.aspx
USA
2010 Ford Fusion I4
2010 Mercury Milan I4
2001 Mercury Villager
OBDLink MX+ BT & EX USB
Launch Smartlink C J2534 USB
vLinker FS USB
Willing to beta test
2010 Ford Fusion I4
vLinker FS USB
raymond973
I do not want to program the remote. I want cancels the Buzer the ignition key that activates whenever the ignition is off and a door is opened.
Last programe added "Reset the Air Intake Throttle Valve Learned Values" for some models. This feature is not available for ranger / mazda 2009?
Raymond
Raymond
These are progranmable parameters, not implemented in FORScan yet.raymond973 wrote: I do not want to program the remote. I want cancels the Buzer the ignition key that activates whenever the ignition is off and a door is opened.
At this moment, no (only since 2011). It needs to be checked if the function is available on these models.raymond973 wrote: Last programe added "Reset the Air Intake Throttle Valve Learned Values" for some models. This feature is not available for ranger / mazda 2009?
