I have a 2003 MK1 Focus ST170.
Would someone be able to tell me if my vehicle uses MS CAN? would I need to do the HS/MS switch modification on my ELM327 for full functionality?
One other question, my vehicle has factory fitted xenon headlights. Does Forscan support the feature to be able to recalibrate the headlights back to "zero"?
Thanks.
Focus MK1
Re: Focus MK1
As far as we know, Focus Mk1 has no MS-CAN bus. Does FORScan t ask about HS/MS CAN switch during the first connect?nitr0uk wrote:Would someone be able to tell me if my vehicle uses MS CAN? would I need to do the HS/MS switch modification on my ELM327 for full functionality?
No, FORScan has no such function yet. But it is quite simple and if you are ready to be a tester for it, we can implement it. If you are interested, please send us a PM.nitr0uk wrote: One other question, my vehicle has factory fitted xenon headlights. Does Forscan support the feature to be able to recalibrate the headlights back to "zero"?
