MAZDA 3 MZ-CD 1.6D
eskorpiao
MAZDA 3 MZ-CD 1.6D
Post by eskorpiao »
Hi there,
I bought you Android version of FordScan, im trying to see if the MAF values are ok, but i dont have any data to compare.
At 3000.rpm i have 72.02 g/sec.
Can you please help?
Best regards
Re: MAZDA 3 MZ-CD 1.6D
Unfortunately, we have no calibration values for parameters. Theoretically they may be available in service manuals and technical databases, but unfortunately we have no a clear way to extract them.
zg3409
Vehicle: Mazda 3 1.6L Diesel with DPF
Post by zg3409 »
I have 1 .6 2008 Mazda Diesel working fine. I used Forscan at 3000 RPM while stopped and 3000RPM while moving on a mostly flat road
First Stopped at 300rpm MAF 60g/sec
Second moving at 3000RPM on a mostly flat road, 4th gear about 100km/h.
So in summary, I think you MAF values should be in the range 40 to 80g/sec
There is info from Mazda on the sensor and testing it. You need a DC voltmeter connected to one of the wires on the sensor. See:
https://euroesi.mazda.co.jp/esicont/eu_ ... 00700.html
key one engine off 8.2V
Key on engine at 2000RPM approx 11.5V
Your value looks OK. I know this thread is a little old. Did you make progress? What is the symptoms of the car?
MAF 3000rpm moving.jpg (431.95 KiB) Viewed 4691 times
MAF 3000RPM parked
MAF 3000RPM parked
MAF 3000rpm parked.jpg (401.03 KiB) Viewed 4691 times
eskorpiao
Post by eskorpiao »
Hi there,
My values where not ok because of a loose pipe.
Now i have 94g/sec or 940 h/sec at 3000rpm. I think in any maf, at 3000rpm, the values must be above 900.
