WiFi On CDMA Cspire Carrier
Wilson Ross
Vehicle: 2 - 05 Explorers, 03 F150, 01 F450, 11 F150, 14 Mu
Post by Wilson Ross »
Please check here: Well guess what the Data must be turned off 4G is a much better signal than yours. If you try to get WiFi to Connent it will make an effort and then tell you the other signal is much faster and reliable. I am not sure that Blue Tooth has to be turned off but the two are next to each other so I hit them both just to be safe. The system I am on is CDMA and you can't do much with it the carrier belives if it will work don't mess with it. How ever with everything set to run your system works great I am sure further down the road I will have some ideas but at the present time I am excited. It would probley be a good idea to warn people when they are having trouble to do away with possible interfering signals, I returned two ELM's that I feel would have worked if I had known about data taking control. :mrgreen:
Test First
Re: WiFi On CDMA Cspire Carrier
Googled this issue a bit and it seems to be an Android bug specific for Galaxy S3:
http://forums.androidcentral.com/t-gala ... lable.html
http://forums.androidcentral.com/t-gala ... ected.html
http://forums.androidcentral.com/samsun ... -wifi.html
There are many threads like this, they also contain some workarounds for this problem.
In other words, it is some kind of local issue.
