Ford kuga 2.0 tdci
can anyone help, forscan outdoor temperature transmitted by the sensor -36 c
OUTTMP -36 c
INCARTMP 120C
AAT 6 c
What OUTTMP means?
Re: outdoor temperature transmitted by the sensor
It means the outside temperature sensor has an open circuit.
Have a look at it.
Have a look at it.
Dumich
- Vehicle: Ford Kuga MK2, diesel 2.0, 140 k c, UFMA, 2014
Hello Guys,
I have the same issue
PCM.OUTTMP and ABS>OUTTMP -19
AAT 17
How did you resolve this issue?
Thank you.
AAT 17
Thank you.
Are you getting a code for anything?
Sometimes a pid will be there even if the vehicle does not have that component.
In those cases the pid value will default to some open circuit value
boosted_diesel
Find the sensor and check for green crusties in the plug. If you can't find it where it should be then as above said.
