Hello
I would like to ask if anyone knows how to remove the speed limiter from the Ford Fusion 2016 2.0 Ecoboost? The limiter is set at 210 km / h
How Remove Speed Limiter Ford Fusion 2016 2.0 Ecoboost ?
Re: How Remove Speed Limiter Ford Fusion 2016 2.0 Ecoboost ?
Hi.
How do you feel this limitation ? "Brutal" when you hit 210 or more slowly when approaching this speed ?
This question because on my C-Max 2.0 TDCi 150hp 2017 (euro), it seems that it is a limiter set to approx 200km/h.
I have a stage 1 so above 200hp and then high speeds are quick to reach but after 180, it is very slow to hit 200.
I done some logs with Forscan about "torque demand", boost pressure, accelerator's pedal and rpm.
Torque and boost are limited by approx 20% by some rpm :
3500 rpm on 4th gear
3000 rpm on 5th gear
2500 rpm on 6th gear
All this corresponding to approx 180km/h. After, the "reduced" boost is sufficient to increase speed but very slowly...
Very annoying.......
- 4th_gear_boost_limit.JPG (333.23 KiB) Viewed 1424 times
- 5th_gear_boost_limit.JPG (335.74 KiB) Viewed 1424 times
- 6th_gear_boost_limit.JPG (333.12 KiB) Viewed 1424 times
