i am trying from a while to program a key in pats
everything works alright , from start to finish , but at the end it says that key was programed succesful but counter didnt increased . And to put key to 0 and back , then recheck counter . Counter indeed is still the same .
it's a key i bought from ebay , probably chinese ..
dtc code returned is b1601
i did tryed a few times and my car is timed secure acces .
what should i do ?
edit , i just checked dtc with elm too , and it says 1600 and 1601
so , probably i should buy other transponder ..
edit 2 - i kept moving the transponder from place to place , and its working properly now
cheers and thank you forscan & everyone that helped for this wonderfull program !
