Cannot connect to 2010 Escape
avandyke246
- Vehicle: Escape, 2.5L 2010
as the title says im having issues connecting to my escape. Either it cant read the pcm or gets hung on trying to read the vehicle info. i tested with another software and it informed me that the voltage from the vehicle was too low which forscan was reporting 3.2 volts from the vehicle. i checked fuses and everything else and can't narrow it down. Gonna try to get ahold of a multimeter to check the thing. Using the obdlink ex adapter recommended by the team.
- Vehicle: *** Ford ***
Re: Cannot connect to 2010 Escape
avandyke246 wrote: Mon Aug 02, 2021 5:16 pm as the title says im having issues connecting to my escape. Either it cant read the pcm or gets hung on trying to read the vehicle info. i tested with another software and it informed me that the voltage from the vehicle was too low which forscan was reporting 3.2 volts from the vehicle. i checked fuses and everything else and can't narrow it down. Gonna try to get ahold of a multimeter to check the thing. Using the obdlink ex adapter recommended by the team.
Are you able to start the engine?avandyke246 wrote: Mon Aug 02, 2021 5:16 pm as the title says im having issues connecting to my escape. Either it cant read the pcm or gets hung on trying to read the vehicle info. i tested with another software and it informed me that the voltage from the vehicle was too low which forscan was reporting 3.2 volts from the vehicle. i checked fuses and everything else and can't narrow it down. Gonna try to get ahold of a multimeter to check the thing. Using the obdlink ex adapter recommended by the team.
avandyke246
come to find out the wired adapter i was using had a broken solder joint on one of the pins got another and it works just fine.
