Hi.
I'm new in forscan forums. I ve read about injector codings. Yesterday i checked my injectors and read the values of them with forscan. i realized that my injectors' numbers matching the cylinder numbers. like:
injector1-cylinder1
injector2-cylinder2
injector3 cylinder3
injector4-cylinder4
as far as i know previous owner of my mondeo mk5 2lt tdci 2015 has changed the injectors.[img]https://ibb.co/WD5xqbZ/img]
injector numbers matches the cylinder numbers.
coreectional values are exactly the same.
i have no problem with the engine right now.
Should i change the order of the correctional values.
injector correction values
Re: injector correction values
first inj is on cylinder 4
Please mate ruler85 or someone if you see that, tell me how i see with forscan and how the injectors work and I can read their values.Thanks!
