Hi
I’m in trouble because my car’s SOBDMC has been bricked. Lot of dtc error…. Forscan cant see the module. The update wasnt success (drain battery), but after in recovery mode it was ok. the modul not visiable in dtc screen only in the old car profile.
I tried to flash the original firmware, but unfortunately the necessary file not available. ( ES78-7P120-GA). I have used vlinker cable and a registered forscan. the car cant move. How can i fix it? should i buy a new module? My car VIN: 3FA6P0SU0ER354975
Thanks any advice!
Tormab
Bricked ford fusion energi SOBDMC
Re: Bricked ford fusion energi SOBDMC
We had to use original ford software and cable to reprogram SOBDMC as a new module!
