Lincoln Navigator 2021
Exo_Strike
Vehicle: F150 FX4 3.5 Ecoboost 2014
Post by Exo_Strike »
Hello!
Got a 2021 Lincoln Navigator that I can't write in the BCM.
I use the last beta build (2.4.4).
Tried the last 2.3.43 build, no luck.
Tried my old dev 2.3.40.test20210322 no luck too.
I got the same issue on the 2021 Bronco last week, but i used only the Build 2.3.40.test20210322
Anyone have clue about this?
Thank you! :)
I have linked the screen shot of the error.
lenko
Vehicle: 2015 Lincoln MKC(Sold), 2006 Mustang GT, Saleen 530 HP
Re: Lincoln Navigator 2021
Post by lenko »
Exo_Strike wrote: Tue Nov 09, 2021 11:23 pm Hello!
Thank you! :)
What are you trying to do or write?
Exo_Strike
I try to write into the BCM, to see if the other configurations from F150 works (Bambi, Start/Stop, etc)
lenko
Post by lenko »
It's possible that Bambi mode isn't available for the Lincoln or Bronco. Lots of differences between a 2014 F150 and the newer Lincoln and Bronco. Sync 2 on the truck and Sync 3 on the other two.
Exo_Strike
I simply can't write in those modules
