Service procedure has been interrupted.
redone17
Vehicle: 2021 Bronco, 2.3L Manual
Post by redone17 »
I was using my OBDLink MX+ flawlessly for the initial Forscan license. Purchased extended license and made sure firmware and Forscan software are up to date and I’m still getting this error when trying to write IPC on a 2021 Bronco.
Any ideas? Perhaps I need to delete a profile and start over or something? Now that I have the 3 year license? Perhaps something is tied up with the old activation code?
cwkd9
Vehicle: 2021 Ford Bronco
Re: Service procedure has been interrupted.
Post by cwkd9 »
I had the same issue and had to download and reinstall the firmware again, then it worked.
https://www.obdlink.com/support/ex/
smartguy69
Post by smartguy69 »
redone17 wrote: Tue Nov 16, 2021 1:27 pm I was using my OBDLink MX+ flawlessly for the initial Forscan license. Purchased extended license and made sure firmware and Forscan software are up to date and I’m still getting this error when trying to write IPC on a 2021 Bronco.
I had a problem with Version 2.3.43 where it wouldn't read BCM central configuration. Works fine with 2.3.41 so I would suggest you try that.
