Проблема с подключением.
mch412
Vehicle: Ford Transit Connect, 1.5 ECOBLUE MT, 2019
Post by mch412 »
Добрый день!
Имеем Wi FI EMC327. К устройству подключаемся а через программу коннект не происходит. Пробовали с другим адаптером Bluethoth - там все ок.
Настройки все верные.
В чем может быть проблема?
Логи:
2022-01-06 12:27:37.612 [IP channel] Socket opened, result 1
2022-01-06 12:27:37.624 [Comm Adapter] Adapter Thread started with id 2D8
2022-01-06 12:27:37.673 [Comm Adapter] Profiling: 48 ms
2022-01-06 12:27:37.705 [Comm Adapter] Profiling: 32 ms
2022-01-06 12:27:37.705 [Comm Adapter] OBDII to RS232 interpreter not found
2022-01-06 12:27:37.705 [Ford Vehicle] Device cannot be identified on IP 0A00A8C0, port 35000
2022-01-06 12:27:37.705 [Ford Vehicle] No ELM on IP 0A00A8C0, port 35000
2022-01-06 12:27:37.717 [Comm Adapter] I'm finishing
2022-01-06 12:27:37.717 [Ford Vehicle] Unable to connect to ELM
2022-01-06 12:28:08.193 [Comm Adapter] I'm finishing
2022-01-06 12:28:08.203 [Comm Adapter] I'm finishing
2022-01-06 12:28:08.216 [IP channel] Socket opened, result 1
2022-01-06 12:28:08.228 [Comm Adapter] Adapter Thread started with id 45C
2022-01-06 12:28:08.279 [Comm Adapter] Profiling: 51 ms
2022-01-06 12:28:08.313 [Comm Adapter] Profiling: 34 ms
2022-01-06 12:28:08.313 [Comm Adapter] OBDII to RS232 interpreter not found
2022-01-06 12:28:08.313 [Ford Vehicle] Device cannot be identified on IP 0A00A8C0, port 35000
2022-01-06 12:28:08.313 [Ford Vehicle] No ELM on IP 0A00A8C0, port 35000
2022-01-06 12:28:08.324 [Comm Adapter] I'm finishing
2022-01-06 12:28:08.324 [Ford Vehicle] Unable to connect to ELM
2022-01-06 12:31:29.607 [Comm Adapter] I'm finishing
2022-01-06 12:31:29.623 [Comm Adapter] I'm finishing
2022-01-06 12:31:29.637 [IP channel] Socket opened, result 1
2022-01-06 12:31:29.649 [Comm Adapter] Adapter Thread started with id 460
2022-01-06 12:31:29.699 [Comm Adapter] Profiling: 50 ms
2022-01-06 12:31:29.734 [Comm Adapter] Profiling: 35 ms
2022-01-06 12:31:29.734 [Comm Adapter] OBDII to RS232 interpreter not found
2022-01-06 12:31:29.734 [Ford Vehicle] Device cannot be identified on IP 0A00A8C0, port 35000
2022-01-06 12:31:29.734 [Ford Vehicle] No ELM on IP 0A00A8C0, port 35000
2022-01-06 12:31:29.746 [Comm Adapter] I'm finishing
2022-01-06 12:31:29.747 [Ford Vehicle] Unable to connect to ELM
2022-01-06 12:32:48.267 [Comm Adapter] I'm finishing
2022-01-06 12:32:48.276 [Comm Adapter] I'm finishing
2022-01-06 12:32:53.276 [IP channel] Socket timed out
2022-01-06 12:32:53.277 [Comm Adapter] Error initializing IP0B00A8C0
2022-01-06 12:32:53.277 [Ford Vehicle] No ELM on IP 0B00A8C0, port 35000
2022-01-06 12:32:53.277 [Comm Adapter] I'm finishing
2022-01-06 12:32:53.277 [Ford Vehicle] Unable to connect to ELM
2022-01-06 12:33:06.812 [Comm Adapter] I'm finishing
2022-01-06 12:33:06.820 [Comm Adapter] I'm finishing
2022-01-06 12:33:06.829 [IP channel] Socket opened, result 1
2022-01-06 12:33:06.842 [Comm Adapter] Adapter Thread started with id 458
2022-01-06 12:33:06.903 [Comm Adapter] Profiling: 60 ms
2022-01-06 12:33:06.936 [Comm Adapter] Profiling: 32 ms
2022-01-06 12:33:06.936 [Comm Adapter] OBDII to RS232 interpreter not found
2022-01-06 12:33:06.936 [Ford Vehicle] Device cannot be identified on IP 0A00A8C0, port 35000
2022-01-06 12:33:06.936 [Ford Vehicle] No ELM on IP 0A00A8C0, port 35000
2022-01-06 12:33:06.949 [Comm Adapter] I'm finishing
2022-01-06 12:33:06.949 [Ford Vehicle] Unable to connect to ELM
2022-01-06 12:53:38.131 [Ford Vehicle] Thread stopped
